Well, the error says it all: two dimensional arrays are currently not supported.
I see two possibilities:
use one of the MultiArray
message types in std_msgs
create your service similar to what e.g. sensor_msgs/Image
is doing, by having a 1D array for the data and an additional parameter for the length of a row, i.e.
int32 a
uint32 step # Full row length in bytes
uint32[] data # actual matrix data, size is (step * rows)
Originally posted by mgruhler with karma: 12390 on 2016-04-27
Comment by Moon on 2016-04-27:
thanks . :)
if I chose the second possibility ; do you know how to return step and data to my client node ??
Comment by mgruhler on 2016-04-27:
Sorry, I don't understand your question.. This is a service, so the client sends the request, and receives the response, which contains step
and data
in this case....
I mean how to write it in server but I found this way
resp=stResponse()
resp.step = 7
resp.data = cell #cell is an array in my server code
return resp
but I have another problem now:
when I tried to print the received array in client it is printed as (1,2,3,4,..) not as the data that was assigned?
please post a new question and provide the respective code (make sure to format it properly using the preformatted text button, the one with 101 on it).
I did , thanks a lot :)
and this the question if want to help
http://answers.ros.org/question/233049/array-as-response-in-python/
Comment by thejose on 2020-10-14:
I don't understand how the second option works. Could you explain it in a little more detail?
Comment by mgruhler on 2020-10-15:
Instead of a two-dimensional array, create a one-dimensional array by putting all rows "behind" each other. With the step
field you define how long (either in bytes or you could also use number of elements) each row ist.
Does this answer your question? If not, I suggest you create a new question where you detail what exactly you don't understand...
Comment by thejose on 2020-10-15:
Thank you! That answered my question.
