Hello,
I want to subscribe to 2 topics in one node and then do some kind of calculations and them publish a TF.
The subscribers that I saw in the tutorials only subscribe to a single topic, do calculations and them publish. How can I make them subscribe to more then one?
For example I need to subscribe to the /odom position of my robot and to the /camera. Different topics, them I want to compute the trajectories but for that I need info from odom and camera.
I also don't understand how I store the information that I get from the callback function, can I use some global variable to store some info and them use that in the other callback function? How do you return info from a callback function?
thx so much.
Originally posted by End-Effector on ROS Answers with karma: 162 on 2015-03-23
You have to create two Subscriber objects, one for '/camera' and one for '/odom'. For both you write an own callback function.
You can't return data from a callback function. In your callback function you can store data to a global variable or to a member variable, which is the preferred way. Then in your main loop process this data.
Originally posted by BennyRe with karma: 2949 on 2015-03-23
Comment by End-Effector on 2015-03-23:
Thx man.
By the way how do you define a global variable. I'm trying to define a nav_msgs/Odometry global variable and I just get millions of errors.
Comment by BennyRe on 2015-03-23:
Just declare a variable outside a function or a class. But using global variables is not a good coding style.
