Hi, is it possible to load all yaml-files in an folder? Like:
<rosparam folder="$(find parameter)/my_params/" />
Originally posted by Tobias Neumann on ROS Answers with karma: 179 on 2014-09-05
According to the roslaunch doc it shouldn't work: "The tag can either reference a YAML file or contain raw YAML text." You could try writing a small node that takes a path and uses rosparam.load_file()
Originally posted by Chrissi with karma: 1642 on 2014-09-05
Comment by Tobias Neumann on 2014-09-05:
Yes I thought about that too, but I thought there might be an easier solution.
But if I write a node, how can I guarantee that all parameters are loaded before my launch file startes the next node that is depending on them?
Comment by Chrissi on 2014-09-05:
One solution would be to offer a service once all parameters are set and to make the other nodes wait for that service to become available before doing anything.
Mh, that would work, but needs more codeing than adding a line for each yaml file in the launch file :(
There might be an different way? Would be a cool feature for rosparam
Comment by Chrissi on 2014-09-06:
We are actually following a database approach to that. In my project we are using mongodb and have a tool that reads yaml files, saves the found parameters in the datacentre and also sets them on the parameter server. You can have a look at this
