Hi, I am new with Gazebo and ROS, I have found out on how to spawn Hokuyo on Gazebo and open Topic Visualization so that I can see what the Laser Scanner is detecting. But, how to retrieve and save the reading data in polar form to be analyzed?
Originally posted by KennyHimawan on ROS Answers with karma: 15 on 2014-07-21
Comment by KennyHimawan on 2014-07-21:
@jc2016 thanks for your answer, for the '$rostopic echo laser_scan_topic', should I put the complete topic name or just the last part??
Comment by jc2016 on 2014-07-21:
I'm not really sure what you mean by the last part. If you use the command $rostopic list you can find the list of all of the topics that are currently being published. Look through that list to find the name you should use. I think it should just be the last part, but check the list to be sure.
Also, I want to emphasize, echoing is not saving. You have to use the rosbag tool to save any of the data. Hope this helps.
@jc2016 it is working, thanks!! :)
