Using the default API documentation generator (Doxygen), the code API docs for http://wiki.ros.org/ackermann_vehicle_gazebo are generated correctly. I want to use Epydoc instead of Doxygen, so I made the following changes:
- In ackermann_vehicle_gazebo/package.xml, I added a rosdoc element:
<export> <architecture_independent/> <rosdoc config="rosdoc.yaml"/> </export>
- In ackermann_vehicle_gazebo, I created a rosdoc.yaml file:
- builder: epydoc config: epydoc.config
- In ackermann_vehicle_gazebo, I created an epydoc.config file:
[epydoc] modules: nodes/*.py docformat: restructuredtext private: no
After making these changes, I received an e-mail from [email protected] with the subject "Build failed in Jenkins: doc-hydro-ackermann_vehicle #13". The mail contains a large number of messages, but I can't determine the error that caused them. What do I need to do in order to generate code API docs with Epydoc instead of Doxygen?
Originally posted by Jim Rothrock on ROS Answers with karma: 792 on 2013-11-12
Comment by joq on 2013-11-12:
It would help to post a link to the Jenkins doc job that failed. Can you run rosdoc_lite
locally on your development system?
Comment by Jim Rothrock on 2013-11-12:
Link: http://jenkins.ros.org/job/doc-hydro-ackermann_vehicle/13/
Yes. If I do the following:
cd catkin_ws/src/ackermann_vehicle/ackermann_vehicle_gazebo rosdoc_lite .
Documentation is written to ackermann_vehicle_gazebo/doc.
