Hello guys!
I'm trying to run a java example interacting with ROS and from Eclipse. I followed this steps (http://www.ros.org/wiki/rosjava/TutorialsRun%20a%20ROS%20Android%20example%20project), and particularly when I type 'rosmake android_tutorial_camera' the output worked, but no .project and .classpath file is created, and hence I can not import the android_tutorial_camera project into Eclipse. Has somebody any idea of this?
Thanks in advance!
Originally posted by biyonder on ROS Answers with karma: 26 on 2013-01-21
Comment by damonkohler on 2013-02-19:
rosjava does not support rosmake. The tutorial you're referencing is horribly out of date and I've deleted it. See http://ros.org/wiki/android_core
But still can't put into operation for higher version android 'android_honeycomd_mr2' ...
Really? Now I can use both 'android_gingerbread_mr1' and 'android_honeycomb_mr2' libraries on eclipse.
Originally posted by KazutoMurase with karma: 116 on 2013-02-13
Comment by LeopoldPodmolík on 2013-02-13:
Sry , now is working because both use same jar files , so when I choose only one as library and masterchooser.jar add to build path every think is now okey ;-)
