I am a novice to beagleboards [1,2], of recent I and my friends have been toying with the idea of replacing the notebook computer in a turtlebot like set up (or even a bare roomba 5XX) with a beagleboard chip. I look for advice from beagleboard/ARM enthusiasts - is this at all possible ?
[1] : http://beagleboard.org/
[2] : http://en.wikipedia.org/wiki/BeagleBoard
Originally posted by Arkapravo on ROS Answers with karma: 1108 on 2012-10-29
Comment by Vegeta on 2012-10-29:
a similar work has been done using the pandaboard which is very similar to the beagleboard. Although its not implemented on an irobot base but would be easier using ROS.. you can check more here http://tirokartblog.wordpress.com/2011/06/28/pandabot-running-ros/
Comment by Arkapravo on 2012-10-29:
@ankitravankar Looks cool ! thank you !
Comment by Vegeta on 2012-11-07:
I would also recommend not to use beagleboard with kinect ... data acquisition is slow and it crashes all the time.. Pandaboard which is beefier and more robust can handle kinect and point cloud nicely. Also it comes with inbuilt bluetooth and wireless so working from workstation pc is possible.
