I'm attempting to set up power failure or intermittent comms resiliency for remote nodes, and I'm not sure if I need to create a custom solution or if roslaunch might be able to do this for me.
My simple test has not yielded positive results but I'm not sure if that's expected.
My simple test situation has indicated that respawn="true" only covers if the single process that represents the remote node goes down will the node be respawned. If roslaunch is taken down or any parent process, it looks like it will not respawn.
My gut says there's not any real way around this, but I figure I should ask:
Can roslaunch
handle respawning remote nodes where remote connection is lost or remote machine goes down via powerfailure?
Originally posted by Asomerville on ROS Answers with karma: 2743 on 2012-08-03
