One of my use-cases for ROS is that I'd like to have a 'thin client' on OS X that can communicate with our Ubuntu ROS master for some simple tasks: perhaps calling a service or querying a parameter from the parameter server.
But the overhead of installing and configuring ROS on our OS X machine is too much, especially because we're trying to build a releasable binary that is pretty much drag-and-drop install on OS X.
The first solution that comes to mind for me is a TCP server running in a ROS node on the Ubuntu machine that provides a limited interface to the ROS world for thin clients to call. Sort of like what ROSBridge tries to do for a web client. Do you know of any mature stacks that implement something like that? Is the idea of running a TCP server in a ROS node unpalatable / full of pitfalls? A sort of standardized interface to ROS for non-ROS clients seems like a common use case, but I don't have a great idea of the technical implications.
Originally posted by isherman on ROS Answers with karma: 132 on 2012-07-27
Comment by Mac on 2012-07-27:
The extreme basics of ROS (generating and sending messages, for example) build just fine on OS X, although I agree that it's a bit messy, and not necessarily suitable for straightaway deployment.
Comment by isherman on 2012-07-31:
@Mac: I do have bare-bones ROS building on OS X, but it takes about an hour and requires various bits of troubleshooting to make it all the way through. If you have any shortcuts I'd be curious.
@JonMace, @ipso: I was nervous about the stability and maintenance of ROSBridge, but I was only aware of v1. v2 looks like it could do the trick. Exciting!
