What you are seeing is probably the physics solver destabilizing, leading to NaN's in link velocities and eventually segmentation fault of the simulator. For objects with deep interpenetration, there is no known cure in ODE/Gazebo right now.
There is, however, something I am experimenting with that may potentially reduce or eliminate these types of numerical "explosion" by using a type of pose projection correction for interpenetrating bodies. You can see the improved interpenetration correction behavior in the following videos for simple shapes in collision and PR2 in collision. Unfortunately, there is no free lunch in this case, in complex dynamical scenarios for PR2, completely removing the original ODE interpenetration correction introduces limit cycles and errors in overall dynamic behavior of the robot: i.e. see PR2 drift backwards in first 3 seconds of this video. Any comments or suggestions are welcome here.
Originally posted by hsu with karma: 5780 on 2012-04-02
Comment by sam on 2012-04-02:
So pose projection correction will solve the problem I have met?
Comment by hsu on 2012-04-07:
maybe, it's experimental, so I wouldn't hold my breadth for it. But for now try not to spawn models that overlaps each other.
