I'd like to use move_arm to send the arm through some trajectory with perhaps some path constraints or something, but with collision checking disabled. What's the easiest way to do that? I've been fiddling with arm_navigation_msgs/OrderedCollisionOperations and setting the operation to 0 for "all" but that doesn't do anything, and I also tried setting things in arm_navigation_msgs/AllowedCollisionMatrix but that didn't work either. Any tips? Incidentally, I'm curious what these messages are supposed to be for, even if they aren't what I want. Thanks!
Originally posted by Ibrahim on ROS Answers with karma: 307 on 2011-12-19
Create a CollisionOperation op and set:
op.object1 = op.COLLISION_SET_ALL
op.object2 = op.COLLISION_SET_ALL
op.operation = op.DISABLE
and add it to the MoveArmGoal.
It sounds like you already tried something similar, but these can be tricky to get exactly right (for example using "all" or all instead of op.COLLISION_SET_ALL doesn't work) so I'd recommend trying it again. I use the collision operations frequently with MoveArm and they do work in the way you expect.
Note that you need to pass the collision operation as part of the move arm goal; it won't work to set the planning scene because MoveArm resets it.
Originally posted by jbarry with karma: 280 on 2011-12-19
Comment by Ibrahim on 2011-12-19:
Ah, I forgot to set object2, and then realized that it was nearly 6am and I should go to sleep. Cool, will try this out in a bit.
