Hi,
After some time trying to find a way to simplify this code in the tutorials of simple publisher, that uses a string and turn it into a twist message but I couldn't. Here's my last effort on it.
That's why I ended up creating a modification of some of the codes that I found. Here is the subscriber and here is the publisher. I got it working, and now I ask myself: Is using tf necessary if the only thing I need is to send and receive data? (cmd_vel for the moment, although later laser_scan info, too). How can it be done? I'm at a loss here, don't know where to go from here (read a lot of documentation and finished the tutorials a couple of times)
Thanks,
Update: Awesome! I got the publisher running, but the subscriber (code here) is giving me some weird compilation problems: here.
@Lorenzo Riano: My basic concern was getting to work a code that sends some sort of speed information. Once that works, my next step is writing something similar with laser_scan. Ultimately, when I get speed control and laser_scan working, I plan to play with it and make a robot move around randomly in a .world map in Stage. So, basically, it all is for simulating it with stage, no real robot involved for now.
@Everybody: What's the best way to showcase that a publisher+subscriber works? Just by printing the message on screen once it gets to the subscriber? What if they don't fully work? Some sort of debugging available?
Originally posted by jlo on ROS Answers with karma: 385 on 2011-11-22
Comment by Lorenzo Riano on 2011-11-24:
rxconsole is your friend here :-)
