Hi All,
I have two nodes: A and B implemented in C++. Now I want Node A to be launched (by the program, not by users' input in the terminal) within the execution of Node B that is launched by users in the terminal. Is there a ROS way to do this? Or should I just encode a shell command in B's source code to launch A, like executing a shell command in C++ programs?
Thanks,
Originally posted by HZ on ROS Answers with karma: 76 on 2011-09-09
