Watch the TurtleBot dashboard video: http://www.youtube.com/watch?v=wDU1Wc9SO7Q.
To set your ROS_MASTER_URI
export ROS_MASTER_URI=http://<TURTLEBOT_IP>:11311
replace < TURTLEBOT_IP > with the IP address of the TurtleBot
to determine the IP address of the TurtleBot
ifconfig
you should see something similar to:
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:36800562 errors:0 dropped:0 overruns:0 frame:0
TX packets:36800562 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3320894268 (3.3 GB) TX bytes:3320894268 (3.3 GB)
wlan0 Link encap:Ethernet HWaddr 48:5d:60:7d:22:e6
inet addr:10.0.129.60 Bcast:10.0.129.255 Mask:255.255.254.0
inet6 addr: fe80::4a5d:60ff:fe7d:22e6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:475034 errors:0 dropped:0 overruns:0 frame:0
TX packets:292561 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:360404726 (360.4 MB) TX bytes:49527301 (49.5 MB)
in the above case < TURTLEBOT_IP >=10.0.129.60
Originally posted by mmwise with karma: 8372 on 2011-09-06
Comment by Brian Gerkey on 2011-09-12:
You can get better performance in X forwarding by also enabling compression with -C, e.g.: ssh -XC turtlebot
Comment by mmwise on 2011-09-10:
to install your ROS on your ubuntu workstation follow the instructions here: http://www.ros.org/wiki/Robots/TurtleBot/diamondback/SDK%20Setup/Ubuntu%20Deb
Comment by ParkerGibbons on 2011-09-09:
Woo! It's working now with the -X command. Thank you so much!
Would I just install the desktop one with " sudo service apt-get ros-diamondback-turtlebot-desktop "?
Comment by mmwise on 2011-09-09:
ahhh you're trying to view the dashboard over ssh.. typically you would install ros-diamondback-turtlebot-desktop on your workstation computer and run the dashboard locally (on the workstation computer) in order to do it over ssh you need to to X forwarding by doing ssh -X when ssh-ing
" Unable to access the X Display, is $DISPLAY set properly?", when I type "rosrun turtlebot_dashboard turtlebot_dashboard&". What is wrong?
@mwise_wg It has helped me set the URI, but I still can't get the dashboard to open on my workstation. I get the message
Comment by mmwise on 2011-09-07:
@ParkerGibbons did this help you?
