Gazebo Answers logo
Hello,
We are looking to run a camera sensor headless on a VM, however when we do so several of the camera's image topic (notably, camera/image_raw) are not published. At ROSCon, I spoke briefly with Jose, who indicated that this could be done fairly painlessly, and is actually used for Gazebo's CI tests. How would I go about enabling that capability?
To clarify, we already have a camera plugin that runs just fine on a display-enabled machine. Our robot is defined in a URDF and launched using roslaunch. However, note that the "headless" option exposed by gazebo_ros_pkgs doesn't actually work - see https://github.com/ros-simulation/gazebo_ros_pkgs/issues/491
I also don't see an explicit "headless" option list in the Gazebo code. The Gazebo devs did mention that such a mode was possible, I just can't figure out how.
(Running Gazebo 7 and ROS Indigo)
Originally posted by JLiviero on Gazebo Answers with karma: 94 on 2016-10-19
3 Answers 3
Gazebo Answers logo
I think it can be done by running the Gazebo server in Headless mode with the following command
gzserver  # then you can use gz topic -l to verify it is running
By default it doesn't have a camera sensor, so you will have to define your own world SDF file with a camera sensor.
The rest is up to you.
Originally posted by chutsu with karma: 36 on 2016-10-19
Comment by JLiviero on 2016-10-24:
As I noted in the question, we already have a camera plugin that runs just fine on a display-enabled machine. Our robot is defined in a URDF and launched using roslaunch. I should have been more clear, sorry - I've updated my original question accordingly.
Comment by nkoenig on 2016-10-25:
gzserver runs headless. Your machine will need an xserver running if you want to render camera data.
Gazebo Answers logo
Hello Jordan:
As Nate has mentioned in the comments, you will need an xserver running to be able to render camera data. In order to have an xserver running with a headless setup and assuming that you are using an Nvidia card, you could use (starting with 331.* driver series):
nvidia-xconfig --allow-empty-initial-configuration
This should generate the following configuration in your Xorg.conf file:
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    Option         "AllowEmptyInitialConfiguration" "True"
EndSection
Hope it helps. Thanks for sharing the feedback in the ROSCon!
Comment by jsather on 2018-08-28:
Hi Jose,
For this to work, do you also need to set up a display server like Xvfb? I am trying to run Gazebo on a Google Compute Engine instance running Ubuntu 16.04 with an Nvidia K80 GPU and have yet to get it working. If you are willing to take a look, I included a few more details in my StackOverflow post: https://stackoverflow.com/questions/52050708/how-to-run-gazebo-on-google-compute-engine-with-gpu
Gazebo Answers logo
Thanks guys. I've got a solution, which I'll post here for the benefit of anyone else who comes searching for such a thing later.
Because our VMs aren't running NVidia drivers as a rule, I wanted to explore some other options before attempting Jose's solution. Based on Nate and Jose's comments, I went digging into virtual xservers and found this old comment, which led me to Xvfb. With Xvfb, I was able to do the following:
$ Xvfb :1 -screen 0 1600x1200x16  &
$ export DISPLAY=:1.0
$ roslaunch etc etc.launch
...which let me run the camera plugin headlessly on a VM with no problems. Here's a screen grab from the camera, taken remotely by connecting RQT to the robot on the VM:
image description
(This timely Gazebo fix was also helpful.)
Thanks again!
Originally posted by JLiviero with karma: 94 on 2016-10-31
Comment by GL on 2017-01-12:
This solution worked with my launch file. Thank you for sharing your fix!
