I would filter the .log files first then playback, see if that helps. The bottom of this tutorial shows how to use the hz filter. Note that filtering a large log file can take a while though.
Originally posted by iche033 with karma: 1018 on 2013-05-15
Comment by Luis Filipe Rossi on 2013-05-15:
I did it.. now it is super fast.. but actuallly faster than it should be. Anyway to control the gazebo update rate so it will run in 1s/s rate?
Comment by nkoenig on 2013-07-30:
Not yet, but that feature is in the works.
Comment by NickDP on 2014-09-26:
Has this feature been implemented yet? Thanks.
