Hi,
I am working on my bachelor-thesis and have a .urdf model I want to load.
First I tried gzsdf convert *.urdf
an got the error [Converter.cc:50] Unable to determine original SDF version
I would also be happy if I can load the .urdf model.
There are different solutions to this problem, but I found no one without ROS. (I use Gazebo without ROS.)
Do you know, what I can do? Thank you.
Originally posted by Zwilling on Gazebo Answers with karma: 21 on 2013-04-08
Comment by hsu on 2013-04-09:
can you post the urdf file?
Comment by Zwilling on 2013-04-19:
The file I want to convert can be found here: http://svn.openrobotino.org/robotino-ros-pkg/trunk/robotino/robotino_description/urdf/robotino.urdf
Comment by Ben B on 2013-04-24:
What version of Gazebo are you using?
Comment by Zwilling on 2013-04-30:
I use Gazebo 1.5.0
Comment by Ben B on 2013-05-06:
I would try upgrading to the latest Gazebo -- though back up anything important. That way, the behaviour of our Gazebo installs will be more likely to coincide.
Comment by Andrew Hundt on 2017-06-05:
updated http://answers.gazebosim.org/question/16376/whats-up-with-sdf-urdf-model-and-world-files/
