I use a plugin to control a hand model with two fingers from a position(0,0,0) to a high position(0,0,0.5), and the model will quiver up and down. The motion is not regular and not smooth, would you please help me? thank you
world file:
<plugin name="animate_pose1" filename="libanimate_pose1.so"/>
the animate_pose.cc:
gazebo::common::PoseAnimationPtr anim(
new gazebo::common::PoseAnimation("box::my_joint5", 10.0, 0));
gazebo::common::PoseKeyFrame *key = anim->CreateKeyFrame(0.0);
key = anim->CreateKeyFrame(0);
key->SetTranslation(math::Vector3(0, 0, 0));
key = anim->CreateKeyFrame(2.0);
key->SetTranslation(math::Vector3(0, 0, 0.1));
key = anim->CreateKeyFrame(4.0);
key->SetTranslation(math::Vector3(0, 0, 0.2));
key = anim->CreateKeyFrame(6.0);
key->SetTranslation(math::Vector3(0, 0, 0.3));
key = anim->CreateKeyFrame(8.0);
key->SetTranslation(math::Vector3(0, 0, 0.4));
key = anim->CreateKeyFrame(10.0);
key->SetTranslation(math::Vector3(0, 0, 0.5));
_parent->SetAnimation(anim);
Originally posted by lugd1229 on Gazebo Answers with karma: 75 on 2013-02-24
