I'm running Webots R2023a where I have a robot node marked as Supervisor in Webots world (*.wbt file) to be controlled by an external node in ROS2 network. When writing a webots-ros2 plugin, I'm faced with an issue where I cannot access robot fields inside the plugin implementation file.
The init function of the plugin provides a WebotsNode object which inherits a ROS2 node:
init(webots_ros2_driver::WebotsNode *node, std::unordered_map<std::string, std::string> &parameters)
However, I need a reference to the current robot as a webots::Supervisor object so I can retrieve nodes and fields of this robot (using the Supervisor API methods) to have full control over various aspects of the simulation.
Is it possible to get a handle to the robot?
Since version 2023.0.0 of the webots_ros2 package, the Robot node (or Supervisor or Driver) cannot be accessed anymore. This is due to the fact that the webots_ros2_driver package (which defines the WebotsNode) doesn't use the C++ API of the libController anymore. Instead it now uses the C API.
Therefore, only the C API can now be used in plugins. You can take a look at the following tutorial: Creating a Custom C++ Plugin which uses the C API to access the robot devices and apply velocities to its motors.
