For the pick and place operation with real Fanuc robot, I am using the following framework, libraries:
- Motion Planning: Moveit2
- Control: ros2_control
- Task Management: Smach State Machine
To be able to check whether the motion is planned successfully , I am using the moveit::core::MoveItErrorCode class
Related section from my Moveit2 action server:
auto arm_move_group = moveit::planning_interface::MoveGroupInterface(shared_from_this(), "arm");
std::vector<double> arm_joint_goal = {j1, j2, j3, j4, j5, j6};
arm_move_group.setJointValueTarget(arm_joint_goal);
moveit::planning_interface::MoveGroupInterface::Plan arm_plan;
auto success = arm_move_group.plan(arm_plan);
if (success == moveit::core::MoveItErrorCode::SUCCESS)
arm_move_group.move();
result->success = true;
goal_handle->succeed(result);
RCLCPP_INFO(get_logger(), "Arm Goal succeeded");
else{
RCLCPP_ERROR(this->get_logger(),"Arm Goal Failed Because: %s" ,moveit::core::error_code_to_string(success).c_str());
result->success = false;
However the result->success = true (line 9) is executed before arm_move_group.move() (line 8) is fully completed which causes synchronization problem for pick and place operation because after action sends the True result, picking process is triggered for the gripper while robot is not reached to gripping pose.
