I am confused on how to build packages that are located inside other folders in the ros2_ws folder. More specifically, my setup is like this: I have a "ros2_ws" directory, which contains "build", "install", "log", and "src" folders. Inside the src folder is a folder called "SDK", and inside the SDK folder there is a directory called "ros2" which is what I'm trying to build. The "ros2" directory has dependencies on files in the "SDK" directory so I can't move it out of there directly into the "src" folder.
In short, the path of the package I'm trying to build is ros2_ws/src/SDK/ros2.
Everytime I try to run colcon build from the ros2_ws directory it only attempts to build the "SDK" directory rather than the "ros2" directory (which is unsucessful since SDK isn't directly ros related). How do I build and run the things inside the actual "ros2" directory from the "ros2_ws" directory?
Note: I'm using Ubuntu 24.04 and ROS2 Jazzy.
This apparently used to work in ROS1, but it doesn't work in ROS2.
