I am designing a local planning system, and based on the suggestions provided on the ROS Wiki, it seems that the real-time reliability of the odom coordinate system is higher. Therefore, I have chosen odom as the planning coordinate system.
However, this has led me to encounter a problem:
Initially, the odom coordinate system and the map coordinate system overlap. However, as the robot moves, the odom coordinate system can drift due to various reasons. Even though I have set odom as the coordinate system for the local costmap (using the Costmap2D class), the values of the original x and y do not change with the drift of the odom. They seem to remain fixed. This results in a high probability of querying invalid results due to out-of-bounds when I use the local costmap to query map obstacles.
Does this mean that I need to switch from odom to map for querying? Is this an unnecessary step? Or is it possible for my local planner to directly use the map coordinate system?
Thank you, everyone.
my costmap configuration is as below
local_costmap:
global_frame: odom
robot_base_frame: base_link
update_frequency: 10.0
publish_frequency: 5.0
#We'll configure this costmap to be a rolling window... meaning it is always
#centered at the robot
static_map: false
rolling_window: true
width: 5.0
height: 5.0
resolution: 0.05
map_type: costmap
origin_x: 0.0 #5.0
origin_y: 0.0
transform_tolerance: 2.0
track_unknown_space: false
plugins:
- {name: voxel_layer, type: "costmap_2d::VoxelLayer"}
- {name: inflation_layer, type: "costmap_2d::InflationLayer"}
- {name: obstacles, type: "costmap_2d::VoxelLayer" }
