I'm having a problem regarding code migration from ROS Noetic to ROS Foxy.
The problem is related to parameter access from scripts. I'm using Python nodes for my code.
Originally these sorts of YAML parameters were acceptable for rospy
YAML file section:
tf_static: [
{"frame_id": "map",
"child_frame_id": "odom",
"translation": [0.0,0.0,0.0],
"rotation": [0.0,0.0,0.0,1.0]
{"frame_id": "base_link",
"child_frame_id": "cam_link",
"translation": [0.06,0.0,0.08],
"rotation": [-0.5,0.5,-0.5,0.5]
a: {
b: 1,
c: 2.0,
d: "hello",
e: true
rospy script section (using if-else rather than get_param w/ defaults for better visibility wherever necessary):
if rospy.has_param('tf_static'):
tf_static = rospy.get_param('tf_static')
else: #defaults
tf_static = [
{"frame_id": "map",
"translation": [0.05,0.0,0.08],
another_param_dict = rospy.get_param('a', default={'b':1,'c':2.0,'d':"hello",'e':True})
just_a_field = tf_static[0]['frame_id'] # just an example
just_another_field = another_param_dict['d'] # just another example to expand
Considering that parameter.py
in the source code does not include this functionality with get_parameter_value
, and parameter_dict_from_yaml_file
simply points to a YAML file to go through the same thing recursively, this becomes a great hassle.
Declaration is another problem, considering nothing in this case is allowed in the first place. I can (only) get a
to work, by explicitly specifying a.b
, a.c
, a.d
, and a.e
, but a list of dictionaries is "non-standard" (not by YAML conventions, of course) so I am completely stuck there.
# self refers to the Node, i.e. `class my_node(Node)`
# ridiculously messy, and only works with "standard" types
self.declare_parameter('a.b',"1")
self.declare_parameter('a.c',"2.0")
self.declare_parameter('a.d',"hello")
self.declare_parameter('a.e',"true")
self.b = self.get_parameter('a.b').get_parameter_value().integer_value
self.c = self.get_parameter('a.c').get_parameter_value().double_value
self.d = self.get_parameter('a.d').get_parameter_value().string_value
self.e = self.get_parameter('a.e').get_parameter_value().bool_value
Furthermore, the original idea of using lists of dictionaries for me was to have as many of these descriptions as I wanted for my static frame definitions so I could simply enter them in my YAML file in this manner. Now I can't even think about using many parameters without typing them in one by one in my rclpy node initialization.
Is this seriously what we are stuck with for moving on with ROS 2, or is there a way to properly get parameters from YAML files? I seriously am considering hacking into the parameter file using ament
packages, or some relative address definitions, and yaml
to just parse the parameter file myself and eliminate the problem. I am not even interested in modifying these parameters at runtime either.
