We are trying to launch a ROS2 subscriber node and publisher node on boot. We are using a systemd service file to launch our launch.py file. When running systemctl status
and viewing the systemctl log, we can see our nodes running and communicating. However, when we run ros2 topic list
, we cannot see the topic over which the nodes are communicating. Why is this and how do we “re-route” the information from the systemctl logs to ROS2 such that we can view the topic and messages directly in ROS2?
(We confirmed that the nodes themselves work when running ros2 run <node_name>
. Here is the service file:
[Unit]
Description=ROS 2 Node Launch Service
[Service]
Type=simple
Environment="HOME=root"
ExecStart=/usr/local/bin/worm7_ros2_launch.sh
[Install]
WantedBy=multi-user.target
Here is the bash file:
#!/bin/bash
source /home/worm7/worms_ws/install/setup.bash
ros2 launch startup startup.launch.py
Here is the launch file:
from launch_ros.actions import Node
return LaunchDescription([
Node(
package='startup',
namespace='startup',
executable='listener',
name='listener'
Node(
package='startup',
namespace = 'startup',
executable='talker',
name='talker'
The code for the publisher and subscriber nodes can be found here: https://docs.ros.org/en/iron/Tutorials/Beginner-Client-Libraries/Writing-A-Simple-Py-Publisher-And-Subscriber.html
Any help is appreciated. Thank you.
