I want to call a service SendError
from a registered callback from an external library. The only way I see I can do this is by having the node declared as a global variable, but I haven't seen any examples of this and I don't know if it's bad practice.
I have tried two different ways that work, with the callback inside the class and outside the class, but it works by declaring the node as a global variable, because the callback function to register has to be static and cannot be able to access the node object.
Outside the class:
#include <iostream>
#include <rclcpp/rclcpp.hpp>
#include <libExt.h>
class Foo : public rclcpp::Node
public:
explicit Foo() : Node("foo")
clientSendError = this->create_client<foo_interfaces::srv::SendError>("send_error");
void sendError(int code)
while (!clientSendError->wait_for_service(1s))
if (!rclcpp::ok())
RCLCPP_ERROR(rclcpp::get_logger("rclcpp"), "Interrupted while waiting for service. Exiting.");
return;
RCLCPP_INFO(rclcpp::get_logger("rclcpp"), "Service not available, waiting again...");
auto requestSendError = std::make_shared<foo_interfaces::srv::SendError::Request>();
requestSendError->code = code;
auto resultSendError = clientSendError->async_send_request(requestSendError);
private:
rclcpp::Client<foo_interfaces::srv::SendError>::SharedPtr clientSendError;
std::shared_ptr<Foo> node;
static void errorNotification(const int32_t *error)
RCLCPP_INFO(rclcpp::get_logger("rclcpp"), "Error notification received");
int errort = *error;
node->sendError(errort);
rclcpp::init(argc, argv);
registerErrorCallback(errorNotification);
node = std::make_shared<Foo>();
rclcpp::spin(node);
rclcpp::shutdown();
return 0;
Inside the class (class has to be declared before node declaration too, which doesn't look too good):
#include <iostream>
#include <libExt.h>
class Foo;
public:
private:
if (!rclcpp::ok())
return;
rclcpp::spin(node);
rclcpp::shutdown();
return 0;
It works, but is this bad practice? If it is, how can I make this work using good practice?
If it's good practice, is it better to have the callback inside or outside the class?
Edit: the library is in pure C.
