I couldn't start turtlebot3 empty world simulation as,
ros2 launch turtlebot3_gazebo empty_world.launch.py here
I'm using Ros2 Foxy on Ubuntu 20.04 with Gazebo 11. But I can start webot turtlebot simulation below command:
ros2 launch webots_ros2_turtlebot robot_launch.py
image description
How can I fix the issues.
Thank you.C:\fakepath\Screenshot from 2022-05-30 10-10-45.png
Originally posted by girayuzun on ROS Answers with karma: 21 on 2022-05-30
Comment by ljaniec on 2022-05-30:
Can you check if you can start gzserver alone?
Your error seems to be the same as another question. Can you try the solution provided there?
Run . /usr/share/gazebo/setup.sh then start Gazebo.
Originally posted by Joe28965 with karma: 1124 on 2022-05-30
I have those lines in my ~/.bashrc for it:
stat /usr/share/gazebo/setup.sh &> /dev/null
if [ $? -eq 0 ]; then
    source /usr/share/gazebo/setup.sh
fi
Comment by girayuzun on 2022-05-30:
both worked for me. Thank you.
Comment by Joe28965 on 2022-05-30:
If it's been solved, could you accept my answer as correct?
