Hi! Im working with the Heron simulating prototype, and what I need is to be able to use the lidar that has already in its packages. The thing is,I have manage to use it, but the ones provided by Heron are pretty big, and the one called "inspection_world" has already being mapped. Is there any map elsewhere, so I could download and try the laser scan? If the map is rather small, better!
Originally posted by LuisCa on ROS Answers with karma: 23 on 2022-01-03
Hi @LuisCa
There is an interesting publication that used Heron robot and trained it with reinforcement learning. New worlds were created and you can use those to test Heron as well. Here is the link to the paper
The fork of this project can be found: https://github.com/AntoineRichard/Heron-RL-ICRA. However some of the links are not working, so you need to dig a little.
For example the uuv_simulator/uuv_gazebo_worlds/worlds/ has other worlds available for simulation for example lake.world: https://github.com/AntoineRichard/uuv_simulator/tree/master/uuv_gazebo_worlds/worlds
image description
Not sure about size, but you can modify them for sure.
Also take a look at the heron_worlds package that was made to help create world specifically for Heron: https://github.com/heron/heron_worlds
Originally posted by osilva with karma: 1650 on 2022-01-03
