I have installed all the stacks along with roomba_robot and serial_communication. Execute "MAKE" for all. I am trying to run this command:
rosrun roomba_500_series roomba560_node which throws below error:
turtlebot@ubuntu:~/myStacks$ rosrun roomba_500_series roomba560_node [ INFO] [1362229508.730474686]: Roomba for ROS 2.01 [FATAL] [1362229508.869236551]: Could not connect to Roomba. [FATAL] [1362229508.869597292]: BREAKPOINT HIT file = /home/turtlebot/myStacks/roomba_robot/roomba_500_series/src/roomba560.cpp line=156
Anyone please suggest if I am missing anything and help me in resolving this problem. It's urgent !! Thank You !!
Originally posted by Devasena Inupakutika on ROS Answers with karma: 320 on 2013-03-02
Comment by Devasena Inupakutika on 2013-03-02:
Error as below:turtlebot@ubuntu:~/myStacks$ rosrun roomba_500_series roomba560_node [ INFO] [1362229508.730474686]: Roomba for ROS 2.01 [FATAL] [1362229508.869236551]: Could not connect to Roomba. [FATAL] [1362229508.869597292]: BREAKPOINT HIT file = /home/turtlebot/myStacks/roomba_robot/roomba_500
Comment by ayush_dewan on 2013-03-02:
Did u change the permission of usb port to which roomba is connected..
Nope. How will changing permission of USB port effect ? I mean I can see that it's detecting at /dev/ttyUSB0.. To what permission do I have to change ?
You mean shall I do this way: chmod 777 <path to USB device which is /dev/ttyUSB0 here > ?
Comment by Devasena Inupakutika on 2013-03-05:
@Shade .. It's working now.. but many times after connection is established, it shows following messages and I am unable to communicate...[ERROR] [1362487447.570308487]: Could not retrieve sensor packets. Please suggest. Thanks.
It's getting disconnected as soon as connection is established..
Comment by KM6VV on 2013-03-05:
Might need to add turtlebot to the group. sudo usermod -a -G dialout turtlebot --but I'm no expert.
Comment by Devasena Inupakutika on 2013-03-06:
Thanks.. Yup tried this one too. But it disconnects as soon as it's connected. Is there any way to achieve persistent connection ? Although it lists in /dev/ttyUSB* but connection is getting disconnected.
There was issue with roomba 521 base's FTDI serial connection due to which it was getting disconnected as soon as it gets connected to roomba. I have tested on two other turtlebots that we have got in lab and everything working fine. Thanks for the help. Can you please accept this and close this as well as other questions that i raised. @shade
Originally posted by Devasena Inupakutika with karma: 320 on 2013-03-08
