Hello,
I am using VSCode
as IDE for my ROS projects. Everything works well, but when I try to import rospkg
, VSCode
underlines it with a yellow line and shows warning message: "Import "rospkg" could not be resolved". When I try to run node with this import, rospkg
works fine, so problem is only with syntax in VSCode
Do you know how to solve it?
Originally posted by Ivan4815162342 on ROS Answers with karma: 5 on 2021-08-25
Comment by Ranjit Kathiriya on 2021-08-25:
Hello @Ivan4815162342,
This is a duplicated question of : #q382798, #q256565
I am closing this question. If you think that you couldn't find a solution feel free to re-open this.
Comment by Ivan4815162342 on 2021-08-25:
I have the paths mentioned in the first link, but that doesn't help. The second link is about the C++
library that is not my case. I should also say that other python imports like rospy
, roslaunch
, rosnode
are not underlined.
