Hi,
I've been trying to get nav2 to run for quite some time and am now facing a problem.
I am using foxy and the the navigation packages released via debian packages.
After launching slam and the base code of my physical robot, I see a map and the robot model https://drive.google.com/file/d/1D2A0A8fKLuCmLNXlIb8imoB3F4ECOC6x/edit
If I now start nav2 (ros2 launch nav2_bringup navigation_launch.py use_sim_time:=False params_file:=/home/config/nav2_params.yaml) nav2 starts to run and I can also see a global costmap. However, the local costmap is not filled and the robot does not respond to any nav 2d goals. Also nothing is published from the controll server on the topic /cmd_vel.
The terminal repeatly prints:
[controller_server-1] [WARN] [1629735747.578710511] [local_costmap.local_costmap]: Sensor origin: (-0.01, -0.04, 0.80), out of map bounds. The costmap can't raytrace for it.
The used configuration is identical to the example from nav2_bringup, only I set "use_sime_time" to "false" everywhere.
Thank you in advance
Originally posted by Mk-_- on ROS Answers with karma: 23 on 2021-08-23
Based on your nav2 settings from your github issue (https://github.com/ros-planning/navigation2/issues/2537), it looks to me like the sensor data is not set up correctly. Maps don't make anything by themselves, they use plugins to fill the data, which in turn use sensor data to fill plugins. The total result is the stack of data of all plugins, from any sensor input. It's a very elegant system imo, but requires some setup.
It looks to me like you have a lidar on your robot which you want to use for mapping. Since the global map seems to work, we can use this as a template and work from there.
In your local costmap, the plugins are a VoxelLayer and an inflation layer. Voxels are used for 3d mapping, and I would think that you are looking for an ObstacleLayer, same as you use for your global map. You can copy the obstacle layer from your global costmap onto your local costmap, and remove the voxel layer. I suggest the following:
local_costmap:
  local_costmap:
    ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      robot_base_frame: base_link
      use_sim_time: False
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 1.0
      plugins: ["obstacle_layer", "inflation_layer"]
      inflation_layer:
        plugin: "nav2_costmap_2d::InflationLayer"
        cost_scaling_factor: 3.0
        inflation_radius: 0.55
       obstacle_layer:
        plugin: "nav2_costmap_2d::ObstacleLayer"
        enabled: True
        observation_sources: scan
        scan:
         topic: /scan
         max_obstacle_height: 2.0
         clearing: True
         marking: True
         data_type: "LaserScan"
     static_layer:
        map_subscribe_transient_local: True
      always_send_full_costmap: True
  local_costmap_client:
    ros__parameters:
      use_sim_time: False
  local_costmap_rclcpp_node:
    ros__parameters:
      use_sim_time: False
The local costmap is necessary for autonomous driving, so I hope that you can get your robot working with this fix.
Originally posted by Per Edwardsson with karma: 501 on 2021-08-26
Comment by Mk-_- on 2021-08-26:
Thank you so much.
Unfortunately I misunderstood the documentation
Comment by Gianstiff on 2022-02-25:
I'm not fully sure if I got the solution. Asking because I'm having the same issue working with a Turtlebot3 robot
