I am working with a 3d lidar 360 degrees lidar. On the robot there are some other sensors and accessories. The sensor scans these objects as well and ros navigation stack treats these objects as an obstacle and never works. I was wondering is there any of filtering the point cloud to some given angles like 0 to 270 as the similar option is available here for pointcloud to laserscan?
I have checked the pcl_ros package and its example filter but I am not able understand which one solves my current problem or which one to use for this issue?
Any leads on the issue are highly appreciated.
Originally posted by Tahir M. on ROS Answers with karma: 213 on 2021-08-18
Comment by gvdhoorn on 2021-08-19:\
what are you using now if not something which converts pointclouds to a LaserScan message? Afaik the navigation stack cannot directly consume pointclouds.
Comment by Tahir M. on 2021-08-19:
At the moment laserscan after filtering. I used pointclouds directly with Navigation Stack and it takes the pole on the robot as an obstacle and never moves. That's the reason I want to filter pointcloud.
I think you can implement this just by iterating through the points and checking points direction with atan2.
Let’s say that you will like to filter points in between theta1 and theta2. Then simply iterate through each point and perform a check;
If(theta1 <= atan2(point.y, point.x) <= theta2) {
  //  Skip this point } else {
  Filteredcloud.points.push_back(point) }
Note that this code has not been tested and is provided only for illustrating an possible solution
Originally posted by Fetullah Atas with karma: 819 on 2021-08-18
Comment by Tahir M. on 2021-08-20:
Thank you this lead solve my issue.
