Problem (TL;DR)
How do I run colcon build with the C++ version set specifically to 17, and without having to manually edit every CMakeList file in my system?
Problem (in detail)
I am currently encountering a problem whilst compiling on a Ubuntu 20 system, with ROS Galactic and ROS2 Foxy both installed. I want to compile my ROS2 code using Galactic (not Foxy) so I have made sure that I have sourced only the setup file for that distro. But when I run colcon build I get a nebulous error that suggests the problem is that a pre-C++17 standard is being used:
/opt/ros/galactic/include/rclcpp/any_subscription_callback.hpp:81:29: error: ‘variant’ in namespace ‘std’ does not name a
template type
   81 |   using variant_type = std::variant<
/opt/ros/galactic/include/rclcpp/any_subscription_callback.hpp:81:24: note: ‘std::variant’ is only available from C++17 onwards
This error doesn't reference any of my code directly, and seems to indicate that the rclcpp package in Galactic is failing to compile because C++17 isn't being used. I'm surprised by this as there are a a few posts around the place suggesting that Galactic requires C++17 (see here) but I couldn't find any reference to this on the Galactic release page. This also doesn't appear to be a known issue with rclcpp (see the issue tracker)
I couldn't find any reference to "CXX" or "C++" versions in the colcon documentation either, but through colcon build help figured out that the following command should in theory set the C++ version:
$ colcon build --cmake-args -DCMAKE_CXX_FLAGS='-std=c++17'
However this doesn't appear to work as I get the same error. I know that I can force individual packages to compile with a specific version using this code snippet in the CMakeList file:
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
However, I would rather not have to change the CMakeList files of all the packages in my codebase, and I'm pretty sure that changing the version via colcon build should have worked. So my questions are:
  1. How do you force colcon to use a specific C++ standard?
  2. Why didn't setting it via -DCMAKE_CXX_FLAGS='-std=c++17' work?
  3. If this isn't the solution to the std::variant build error, can someone please point me in the direction of the solution?
I suspect that the cause of the std::variant build error has something to do with the fact that I have Foxy installed on the same system. But I haven't worked out why yet.
Originally posted by M@t on ROS Answers with karma: 2327 on 2021-08-10
Comment by gvdhoorn on 2021-08-10:\
how did you install ROS?
Comment by M@t on 2021-08-12:
Docker container with an image pulled from osrf/ros:foxy-desktop or osrf/ros:galactic-desktop.
As you already know, asking multiple questions in a single post is not really a good idea, so:
this would seem to be the actual question.
With the information in your current post I can't say what is causing your problem.
rclcpp on Galactic already sets the C++ version to 17 (from here):
# Default to C++17
  set(CMAKE_CXX_STANDARD 17)
endif()
You should not need to change anything there.
To see what's happening, you could try to see what Colcon CMake is actually executing with:
colcon build \
  --event-handlers console_direct+ \
  --cmake-args \
    -DCMAKE_VERBOSE_MAKEFILE=ON
(and perhaps a --packages-up-to or --packages-select to avoid trying to build everything)
That could give you a clue as to which exact commands are being executed.
Having written that: overriding the specific C++ standard for a CMake project isn't really anything specific to Colcon, but more a CMake "thing".
You don't set CMAKE_CXX_FLAGS to -std=c++17, but set CMAKE_CXX_STANDARD to 17 directly.
I would expect the command you show to work with that one change (I like to split things across multiple lines for readability, this is still just a single command):
colcon build \
  --cmake-args \
    -DCMAKE_CXX_STANDARD=17
(make sure to remove the build directory from your workspace to avoid CMake caching things)
If it still doesn't work, that would imply something else is wrong.
PS: note that if you'd like to build only specific packages with specific cmake-args, you'd use a Colcon meta file. The command line as proposed by you will apply to all packages built by that specific Colcon invocation.
It's stated here, in REP 2000: ROS 2 Releases and Target Platforms: Galactic Geochelone (May 2021 - November 2022):
Minimum language requirements:
  • C++17
as well as on the Galactic version of the Code style and language versions page:
Standard
Galactic targets C++17.
Originally posted by gvdhoorn with karma: 86574 on 2021-08-10
Comment by M@t on 2021-08-11:
Thanks for the help gvdhoorn! You're right, I probably should have separated this into two questions. I was in a rush and got lazy. Building with C++17 did solve the problem though!
Comment by gvdhoorn on 2021-08-12:
So are you enabling C++17 in your own package(s)?
Not initially, as my own packages only require C++11 or 14.
Then how would you #include a header which does require C++17?
Well, the contents of my packages don't require C++17, but many have use a similar snippet of code to what you posted in your answer in their CMakeLists file to set CMAKE_CXX_STANDARD to C++14.
When I posted this question I didn't understand how this error could be occurring. But looking back through my code and your answer, what I think has happened is those code snippets have set the CMAKE_CXX_STANDARD to 14. I assume that this is a global flag, so when those packages include various rclcpp headers from (in this case) Galactic, that C++ standard is applied to the compilation of those Galactic headers (which need C++17 minimum). My CMake knowledge is pretty patchy in this area, so please correct me if any of this is wrong.
Comment by gvdhoorn on 2021-08-12:\
no, it's per-package, local only.
CMake projects can export that requirement using target_compile_features(..), but you must link to such projects / libraries using target_link_libraries(..) and I'm not exactly sure (any more) whether Ament doesn't interfere there.
Ah, there goes my theory then. Ament causing extra complication is entirely possible, since I've been using ament_auto a lot to try and simplify my CMakeList files.
Just to clarify: it's local in the sense it's not automatically exported to other packages.
But if you set a specific standard for your package, and then include headers from other projects, those headers will be #included by the compiler under the standard you've set for your package.
So this:
is essentially correct (ie: C++17-requiring headers are interpreted as C++14 due to your local standard selection).
That was also why I asked:
However, if a CMake project uses target_compile_features(..) and exports that target, your local C++14 would be overridden by the C++17 of the target you target_link_libraries(..) against.
But again, that's plain CMake. I've not verified whether Ament respects all of that.
Ah, I think I see. I appreciate the thorough explanation, and it gives me a few places to start for further reading.
