Hello everyone, I have a question related to rviz2. I am trying to display an urdf and rviz2 show this:
image description
I got the tf but I can't represent the 3D models.
Thank you
Originally posted by jarain78 on ROS Answers with karma: 9 on 2021-08-08
Assuming you're using the robot_state_publisher package to publish your TFs, it also publishes the contents of the URDF file of the robot you're using to a topic robot_description.
In RViz, in the Displays panel, open up RobotModel, and change Description Topic to /robot_description. (This makes the RobotModel visualization in RViz listen to the model of the robot from the robot_state_publisher).
Also, make sure Visual Enabled is ticked under Robot Model.
You should be able to see your own robot, like below (or whatever robot you're using)
image description
Originally posted by ijnek with karma: 460 on 2021-08-12
Comment by Abubakar on 2022-07-13:
Hello ijnek, I also have the same problem and I tried as you mentioned above but still no robot showed up do you have any idea where I might be wrong
Comment by ijnek on 2022-07-14:
@Abubakar Would you be able to post a new question (with more details) in ROS Answers and post a link here?
Comment by Abubakar on 2022-07-14:
It's ok ijnek the problem was solved the robot did show up but it was very small that i couldn't spot initially
