Hello,
I am trying a segment tracking algorithm. Right now I have 2 segments. I am coloring each segment with different RGB values, pushing the segments into output_cloud which is pcl::PointCloud2pcl::PointXYZRGB and publishing the output cloud.
The issue I am facing is when I see the PointCloud from RVIZ, I am getting only a single color for both (all) the segments. I have checked the correctness of assigning the RGB values by doing this:
 // checking colors
        int prev_r = 0;
        int prev_g = 0;
        int prev_b = 0;
        int counter = 0;
        for (pcl::PointXYZRGB point : output_cloud) {
            if (prev_r != point.r) {
                std::cout << int(point.r) << " " << int(point.g) << " " << int(point.b) << std::endl;
                std::cout << counter << std::endl;
                counter = 0;
            prev_r = point.r;
            prev_g = point.g;
            prev_b = point.b;
            counter++;
        pub_cloud.publish(output_cloud);
This is what I get (which I think is correct):
Size of segNo_cloud[0] :1168
Size of output_cloud: 1168
Size of segNo_cloud[1] :40680
Size of output_cloud: 41848
16 85 230
210 15 236
1168
40680
Originally posted by nayan on ROS Answers with karma: 26 on 2021-08-02
Update: I fixed the issue! Everything was correct, but I was not clearing the vectors after assigning the segments due to which some segments were overwritten. Hope this helps someone :)
Originally posted by nayan with karma: 26 on 2021-08-05
