The env I am using is ROS Noetic and VS Code along with Pylance.
  1. launching rospy nodes is working fine
  2. importing rospy gives a squiggle error in VSCode.
  3. Also, python syntax is not being highlighted properly. Along with that, I am also not getting auto-complete options.
I think it should be a configuration issue, but I don't know where and what I have to configure to resolve this. Any help would be appreciated.
Originally posted by krushnal on ROS Answers with karma: 5 on 2021-07-19
Hello there,
You have to add 2 python paths into your settings.json file into VS Code.
These are the paths: The first path is for all packages of your local workspace and the second is for the global package.
    "python.autoComplete.extraPaths": [
        "/home/<pc-name>/<ws-name>/devel/lib/python3/dist-packages",
        "/opt/ros/noetic/lib/python3/dist-packages"
If you are using CPP then you have to add the path in the c_cpp_properties.json file.
The location of setting and c_cpp_properties JSON files will be :
 "~/<work-space>/devel/include"
Just to note for Pycharm Users: if you are using Pycharm then give this both paths by following these steps:
  1. Go to settings.
  2. Project: src > Project Structure > On the right-hand side click on + Add Content Root and locate both paths.
Try this you will be able to solve your problem and if you have any issues feel free to drop a comment.
Originally posted by Ranjit Kathiriya with karma: 1622 on 2021-07-19
Post score: 6
Comment by krushnal on 2021-07-19:
thanks a lot .... that solves it!!!
