Hi,
I don't understand why I cannot load the config file for RVIZ automatically using a python script.
The script is the following:
import os
from ament_index_python.packages import get_package_share_directory
from launch                      import LaunchDescription
from launch.actions              import DeclareLaunchArgument
from launch.substitutions        import LaunchConfiguration
from launch_ros.actions          import Node
    config_file_name = 'config_file.rviz'
    print("Loading RVIZ config file: {}".format(config_file_name))
    rviz_config = os.path.join(get_package_share_directory('HHH'), config_file_name)
    return LaunchDescription([DeclareLaunchArgument('use_sim_time',
                                                    default_value = 'false',
                                                    description   = 'Use simulation clock if true'),
                              Node(package    = 'rviz2',
                                   executable = 'rviz2',
                                   name       = 'rviz2',
                                   output     = 'screen',
                                   arguments  = ['-d', rviz_config]),
the file config_file.rviz is stored in the package directory under config:
'package_name'
-> /config
    --> config_file.rviz
    --> params.yaml
-> /urdf
    --> urdf_model.xml
-> /'package_name'
    -->  publisher_node.py
starting the node with:
ros2 launch HHH launch_rviz.py
RVIZ starts, but it doesn't load the config file automatically as expected.
I compile the package with:
colcon build 'package_name'
or
colcon build --symlink-install
but it doesn't copy my config file into the share directory under install.
What's wrong?
Thx!
PS: moving the config file into share manually fixes the issue. But it get "resetted" from time to time
Originally posted by Andromeda on ROS Answers with karma: 893 on 2021-07-15
I fixed this problem by simpling leaving the config file config_file.rviz where it is in the package directory.
I then changed the setup.py where it searchs for the config file in the package directory (using glob and path) and not in the install direcory.
colcon doesn't work properly. Sometimes I realize that I need to delete all the folders install, build and log because colcon keeps old codes there without taking the new changes...
Originally posted by Andromeda with karma: 893 on 2021-07-27
