Hello all,
I am writing a package written in c++ for ros-melodic on ubuntu 18.04.
I need to send service call to a node that takes 3 values as following service call from terminal to change LED color.
$ rosservice call /set_led_color "red: ###
green: ###
blue: ##"
The node have service file definition under "node_name/srv" as Color.srv and its contents as following
int64 red
int64 green
int64 blue
And in node.py the service is coded as
from omo_r1mini_bringup.srv import Color, ColorResponse
rospy.Service('set_led_color', Color, self.save_led_color_service_handle)
def save_led_color_service_handle(self, req):
command = "$sCOLOR," + str(req.red) + ',' + str(req.green) + ',' + str(req.blue)
self.ph.write_port(command)
return ColorResponse()
I tried to initialize my service client by
svc_client = n.serviceClient("/set_led_color", true);
however it is not working.
Originally posted by kyubot on ROS Answers with karma: 60 on 2021-07-11
I did not add below lines in package.xml
<build_depend>std_msgs</build_depend>
<build_depend>message_generation</build_depend>
<run_depend>std_msgs</run_depend>
and then it is able to generate service header according to the service files defined in srv folder.
In my node.hpp file I added
#include "r1mini_gui_teleop/Color.h"
private:
ros::ServiceClient serviceClient; //Client node to call service
my_node::Color serviceSetColor; //Service set color
And in node.cpp file
init(...){
serviceClient = n.serviceClient<r1mini_gui_teleop::Color>("/set_led_color");
some function(...) ...
serviceClient.call(serviceSetColor);
Solved my problem.
Originally posted by kyubot with karma: 60 on 2021-07-11
