ROS2 - FOXY
I have setup two ROS2-Foxy environments with ROS_DOMAIN_ID=0:
  1. RaspberryPi 3B+ Ubuntu 20.04 64-bit Server
    • Ubuntu ufw is disabled
  1. VMware Fusion running Ubuntu 20.04 64-bit Desktop
    • ROS2 Foxy
    • on Ubuntu 20.04.2 LTS 64-bit Desktop
    • in an 8 GB Ram 3-cores available to VMware Fusion virtual machine
    • on a 32GB 3.2GHz 6-Core Intel Core i7 2018 MacMini
    • running macOS Big Sur 11.0.1
    • Bridged Network Adapter (same if Bridged Ethernet or Bridged WiFi)
  • Each system will successfully communicate (localhost) for
    "T1: ros2 run demo_nodes_cpp talker" and
    "T2: ros2 run demo_nodes_py listener"
    (any combination of cpp/cpp, py/cpp, cpp/py, py/py )
  • Each system is able to ping to the other
  • Both systems ifconfig report
    UP,BROADCAST,RUNNING,MULTICAST
  • Multicast test works one way - to the VM
    ROS-VM: ros2 multicast recieve
    Waiting for UDP multicast datagram...
    Received from 10.0.0.11:43044: 'Hello World!'
    ROSbot: ros2 multicast recieve does not succeed
  • Both systems have ROS_DOMAIN_ID=0
  • Both systems have ROS_LOCALHOST_ONLY=0
BUT when I run a talker on one system and listener on the other, the listener never reports receiving the "Hello World" topic.
On RaspberryPi ROSbot running the talker, "ss -tulw" reports:
pi@ROSbot:~$ ss -tulw
Netid          State            Recv-Q           Send-Q                       Local Address:Port                          Peer Address:Port          Process
icmp6          UNCONN           0                0                         *%wlan0:ipv6-icmp                                *:*
udp            UNCONN           0                0                        0.0.0.0:7400                               0.0.0.0:*
udp            UNCONN           0                0                        0.0.0.0:7412                               0.0.0.0:*
udp            UNCONN           0                0                        0.0.0.0:7413                               0.0.0.0:*
udp            UNCONN           0                0                      127.0.0.1:58641                              0.0.0.0:*
udp            UNCONN           0                0                        0.0.0.0:34723                              0.0.0.0:*
udp            UNCONN           0                0                  127.0.0.53%lo:domain                             0.0.0.0:*
udp            UNCONN           0                0                10.0.0.11%wlan0:bootpc                             0.0.0.0:*
tcp            LISTEN           0                4096                   127.0.0.1:45585                              0.0.0.0:*
tcp            LISTEN           0                4096               127.0.0.53%lo:domain                             0.0.0.0:*
tcp            LISTEN           0                128                      0.0.0.0:ssh                                0.0.0.0:*
tcp            LISTEN           0                128                         [::]:ssh                                   [::]:*
tcp            LISTEN           0                100                          *:8888                                     *:*
and the ROS2 virtual machine reports:
ubuntu@rosdesk:~$ ss -tulw
icmp6  UNCONN  0       0                                       *:ipv6-icmp                    *:*
udp    UNCONN  0       0                               127.0.0.1:39592                  0.0.0.0:*
udp    UNCONN  0       0                                 0.0.0.0:60176                  0.0.0.0:*
udp    UNCONN  0       0                                 0.0.0.0:37045                  0.0.0.0:*
udp    UNCONN  0       0                                 0.0.0.0:631                    0.0.0.0:*
udp    UNCONN  0       0                                 0.0.0.0:mdns                   0.0.0.0:*
udp    UNCONN  0       0                                    [::]:44486                     [::]:*
udp    UNCONN  0       0         [fe80::79:fbba:db15:6c00]%ens33:dhcpv6-client             [::]:*
udp    UNCONN  0       0                                    [::]:mdns                      [::]:*
tcp    LISTEN  0       5                               127.0.0.1:ipp                    0.0.0.0:*
tcp    LISTEN  0       5                                   [::1]:ipp                       [::]:*
Ideas to try?
Update: It worked and then it didn't again:
Well - when you need some magic, update everything on both systems!
sudo apt-get update
sudo apt-get upgrade
Voila:
pi@ROSbot:~/rosbot-on-gopigo3$ ros2 run demo_nodes_cpp listener
[INFO] [1625930607.244627442] [listener]: I heard: [Hello World: 9]
[INFO] [1625930608.245326225] [listener]: I heard: [Hello World: 10]
[INFO] [1625930609.245479175] [listener]: I heard: [Hello World: 11]
[INFO] [1625930610.244978271] [listener]: I heard: [Hello World: 12]
[INFO] [1625930611.245139866] [listener]: I heard: [Hello World: 13]
[INFO] [1625930612.245483542] [listener]: I heard: [Hello World: 14]
ubuntu@rosdesk:~/handsonros2$ ros2 run demo_nodes_cpp listener
[INFO] [1625930576.490056884] [listener]: I heard: [Hello World: 1]
[INFO] [1625930577.489776977] [listener]: I heard: [Hello World: 2]
[INFO] [1625930578.489909352] [listener]: I heard: [Hello World: 3]
[INFO] [1625930579.489984629] [listener]: I heard: [Hello World: 4]
[INFO] [1625930580.489982903] [listener]: I heard: [Hello World: 5]
[INFO] [1625930581.490141665] [listener]: I heard: [Hello World: 6]
Magic.
BUT WHAT DO YOU DO WHEN IT STOPS WORKING AGAIN AND NOTHING TO UPDATE?
I guess I used up all my luck and magic. Tried again today and it's back to no worky!
Originally posted by RobotDreams on ROS Answers with karma: 327 on 2021-07-09
Comment by vinny on 2021-07-09:
Can you try running the multicast test as listed here: https://docs.ros.org/en/foxy/Guides/Installation-Troubleshooting.html#enable-multicast
I wonder if there is something in the VM network driver.
Comment by RobotDreams on 2021-07-09:
multicast worked one-way: to the VM only.
I performed the sudo ufw commands substituting my local net 10.0.0.0/4 not 224.0.0.0/4 - correct? No change in send from VM no RX on ROSbot
Comment by vinny on 2021-07-09:\
Comment by gvdhoorn on 2021-07-09:
Is the VM configured with a bridged network adaptor? Or a host-only? Or a NAT one?
Comment by RobotDreams on 2021-07-11:
Wow - hope and then hopes dashed. @gvdhoom - tried both bridged ethernet and bridged WiFi - does not fix.
What should I check on WiFi router? I'm wondering if something there is blocking DDS - it is strange that the multicast test works only one way.
Thought I had it by setting optional: false in /etc/netplan/50-cloud-init.yaml - booted 7 times with ping, ssh, and DDS success. Went to celebrate. Came back and couldn't ssh in first boot. Too much to solve.
Currently, ROSbot Dave
has successfully booted up with full ssh, ping, arp, and ROS2 dynamic discovery Data Distribution System DDS working
  • 12 out of 12 attempts
  • since the change of 2.4GHz band WiFi access point
    • from the xFinity Technicolor CGM4331COM XB7 router
    • to my ancient DLink DIR-825 (last firmware released was 2013).
While I can say Carl and DeskPi have had fitful connections with the xFinity router(s), neither has shown the “cannot remote in” (ssh) issue that Dave exhibited, nor did I attempt distributed data messaging across the network when Carl was trying out ROS (1).
Carl has always been a Raspberry Pi 3B based GoPiGo3, but DeskPi was in fact using the exact Raspberry Pi 3B+ (plus) board that GoPiGo3 ROSbot Dave is running, except DeskPi has always run Raspbian/PiOS.
All these tests seem to point the finger at Ubuntu 20.04.2 on RaspberryPi 3B+ (or at least this particular 3B+) having unreliable ICMP, ARP, or UDP handling during the DHCP link establishment phase with the xFinity router configured with a reserved IPv4 address for the board’s WiFi MAC address.
I don’t know enough to be able to diagnose this deeper, and having found a solution that enables me to progress with my ROS2 learning (through migrating the “Hands On ROS for Robotic Programming” exercises), I am leaving this mystery of the universe unsolved.
I do have a new WiFi 6 router on order, (that has ongoing firmware update support), to minimize the chance my network will become a crypto-bot or participant in the next distributed denial of service attack on internet democracy.
Calling this success - Onward with ROS2
image description
Originally posted by RobotDreams with karma: 327 on 2021-07-13
