I create a permanent service, and its client in my launch file. All subsequent service calls fail. I have discovered that if I kill the client and run it from the command line, then the service calls work. The service also works if I call it directly from the command line using 'rosservice'.
I have also discovered that making the service temporary solves the issue. I suspect that the launch file does something before the service is ready, but I don't know what.
I still want to use a permanent service for efficiency. What can I do to fix the problem ?
Originally posted by elpidiovaldez on ROS Answers with karma: 142 on 2021-07-06
Comment by gvdhoorn on 2021-07-07:
Is permanent actually persistent here?
Comment by elpidiovaldez on 2021-07-12:
Yes, I did mean 'persistent'. I don't even remember where I got the idea they were called 'permanent' connections now. It was something I read while investigating them.
I found a discussion on ROS Answers which solved the issue for me. It is here.
I simply needed to wait for the service to be created, by the launch file, before I create the service client. The way to do it is shown below:
void InitializeTTS(ros::NodeHandle &n) {
  ros::service::waitForService("/tts");
  TTSclient = n.serviceClient<tts_serv::Gtts>("/tts",true);
Thanks to @appie for the advice. I looked at rosparam documentation, but I could not see how to use it to solve my issue.
Originally posted by elpidiovaldez with karma: 142 on 2021-07-12
