Good day
Note: I have found out that my code works. I have placed a minor explanation to be further expounded.
I have been having trouble obtaining the right directional output from my implementation. I noticed that every time I put an obstacle at the right, it gives left, it gives the right steering direction, the problem is with the presence of a left obstacle where it still tends to steer itself towards that obstacle. I have checked the occupancy map generated using matlab and was found to be correct. I couldn't pinpoint what is exactly wrong with my code for I have been debugging this for almost a week now and was hoping if someone can see the error I cannot.
Here is my code implementation:
//1st:: Create Occupancy Grid from Data-------------------------------------------------
// > Cell Size/Grid Resolution = 5meters/33 cells = 0.15meters each = 15cm each
// > Grid Dimension = 5meters by 5meters / 33x33 cells //Field of view of robot is 54 degrees
//or 31 meters horizontal if subject is 5 meters away
// > Robot Width = 1meter 100cm
// > Because the focal length of the lens is roughly the same as the width of the sensor,
// it is easy to remember the field of view: at x meters away, you can see about x meters horizontally,
// assuming 4x3 stills mode. Horizontal field of view in 1080p video mode is 75%
// of that (75% H x 55% V sensor crop for 1:1 pixels at 1920x1080).
//Converting the Position into an Angle--------------------------------------------
//from:
// A. https://decibel.ni.com/content/docs/DOC-17771
// B. "USING THE SENSOR KINECT FOR LANDMARK" by ANDRES FELIPE ECHEVERRI GUEVARA
//1. Get angle
// > Each pixel from the image represents an angle
// > angle = ith pixel in row * (field of view in degrees/number of pixels in row)
// > field of view of Pi camera is 54 degrees horizontal
//2. Convert Polar to Cartesian
// > x = z*cos(angle)
// > y = z*sin(angle)
int arrOccupancyGrid[33][33];
float matDepthZ[33][33];
int robotPosX = 0;
int robotPosY = 0;
int xCoor=0; //Coordinates of Occupancy Map
int yCoor=0;
int xPosRobot=0; //Present cordinates of robot
int yPosRobot=0;
float fov = 54; // 54 degrees field of view in degrees must be converted to radians
float nop = 320; //number of pixels in row
int mapDimension = 33; // 33by33 array or 33*15cm = 5mby5m grid
int mapResolution = 15; //cm
//Limit max distance measured
for(i=0; i< nop ;i++){
if(arrDepthZ.at(i)>500){
arrDepthZ.at(i) = 500;
for (i=0 ; i < nop; i++){
//Process data/Get coordinates for mapping
//Get Angle
int angle = ((float)(i-160.0f) * ((float)fov/(float)nop)); //if robot is centered at zero add -160 to i
//cout << "arrDepthZ " << arrDepthZ.at(i) << endl;
//cout << "i " << i << endl;
//cout << "fov " << fov << endl;
//cout << "nop " << nop << endl;
//cout << "angle " << i * (fov/nop) << endl;
arrAngle.push_back(angle);
//Get position X and Y use floor() to output nearest integer
//Get X --------
xCoor = (arrDepthZ.at(i) / mapResolution) * cos(angle*PI/180.0f); //angle must be in radians because cpp
//cout << "xCoor " << xCoor << endl;
arrCoorX.push_back(xCoor);
//Get Y --------
yCoor = (arrDepthZ.at(i) / mapResolution) * sin(angle*PI/180.0f); //angle must be in radians because cpp
//cout << "yCoor " << yCoor << endl;
arrCoorY.push_back(yCoor);
//Populate Occupancy Map / Cartesian Histogram Grid
if((xCoor <= 33) && (yCoor <= 33)){ //Condition Check if obtained X and Y coordinates are within the dimesion of the grid
arrOccupancyGrid[xCoor][yCoor] = 1; //[increment] equate obstacle certainty value of cell by 1
matDepthZ[xCoor][yCoor] = arrDepthZ.at(i);
//cout << "arrCoorX.size()" << arrCoorX.size() << endl;
//cout << "arrCoorY.size()" << arrCoorY.size() << endl;
for (i=0 ; i < arrCoorX.size(); i++){
file43 << arrCoorX.at(i) << endl;
for (i=0 ; i < arrCoorY.size(); i++){
file44 << arrCoorY.at(i) << endl;
for (i=0 ; i < arrDepthZ.size(); i++){
file45 << arrDepthZ.at(i) << endl;
//------------------------- End Create Occupancy Grid -------------------------
//2nd:: Create 1st/Primary Polar Histogram ------------------------------------------------------
//1. Define angular resolution alpha
// > n = 360degrees/alpha;
// > set alpha to 5 degrees resulting in 72 sectors from 360/5 = 72 ///// change 180/5 = 35
//2. Define number of sectors (k is the sector index for sector array eg kth sector)
// > k=INT(beta/alpha), where beta is the direction from the active cell
//to the Vehicle Center Point (VCP(xPosRobot, yPosRobot)). Note INT asserts k to be an integer
cout << "2nd:: Create 1st/Primary Polar Histogram" << endl;
//Put this at the start of the code away from the while loop ----------------
int j=0;
int sectorResolution = 5; //degrees 72 sectors, alpha
int sectorTotal = 36; // 360/5 = 72 //// change 180/5 = 36
int k=0; //sector index (kth)
int maxDistance = 500; //max distance limit in cm
//vector<int>arrAlpha; //already initiated
float matMagnitude[33][33]; //m(i,j)
float matDirection[33][33]; //beta(i,j)
float matAngleEnlarge[33][33]; //gamma(i,j)
int matHconst[33][33]; //h(i,j) either = 1 or 0
float robotRadius = 100; //cm
float robotSafeDist = 50; //cm
float robotSize4Sector = robotRadius + robotSafeDist;
for (i=0; i<sectorTotal; i++){
arrAlpha.push_back(i*sectorResolution);
//---------end initiating sectors----------
//Determine magnitude (m or matMagnitude) and direction (beta or matDirection) of each obstacle vector
//Modify m(i,j) = c(i,j)*(a-bd(i,j)) to m(i,j) = c(i,j)*(dmax-d(i,j)) from sir Lounell Gueta's work (RAL MS)
//Compute beta as is, beta(i,j) = arctan((yi-yo)/(xi-xo))
//Enlarge robot and compute the enlargment angle (gamma or matAngleEnlarge)
int wew =0;
int firstfillPrimaryH = 0; //flag for arrayPrimaryH storage
for (k=0; k<sectorTotal; k++){
for (i=0; i<mapDimension; i++){
for (j=0; j<mapDimension; j++){
//cout << "i" << i << "j" << j << "k" << k << endl;
//cout << "mapDimension" << mapDimension << endl;
//cout << "sectorTotal" << sectorTotal << endl;
//Compute magnitude m, direction beta, and enlargment angle gamma
matMagnitude[i][j] = (arrOccupancyGrid[i][j])*( maxDistance-matDepthZ[i][j]); //m(i,j)
//cout << "matMagnitude[i][j]" << (arrOccupancyGrid[i][j])*( maxDistance-matDepthZ[i][j]) << endl;
matDirection[i][j] = ((float)atan2f( (float)(i-yPosRobot), (float)(j-xPosRobot))*180.0f/PI); //beta(i,j)
//cout << "matDirection[i][j]" << ((float)atan2f( (float)(i-yPosRobot), (float)(j-xPosRobot))*180.000/PI) << endl;
//cout << "matDepthZ[i][j]" << matDepthZ[i][j] << endl;
if(matDepthZ[i][j] == 0){ //if matDepthZ[i][j] == 0; obstable is very far thus path is free, no enlargement angle
matAngleEnlarge[i][j] = 0; //gamma(i,j)
//cout << "matAngleEnlarge[i][j]" << 0 << endl;
else{ //if matDepthZ[i][j] > 0 there is an obstacle so compute enlargement angle
matAngleEnlarge[i][j] = asin( robotSize4Sector / matDepthZ[i][j])*180/PI; //gamma(i,j)
//cout << "matAngleEnlarge[i][j]" << asin( robotSize4Sector / matDepthZ[i][j])*180.0f/PI << endl;
wew = k*sectorResolution; //k*alpha
//cout << "wew" << k*sectorResolution << endl;
//Check if magnitude is a part of the sector
if ( ((matDirection[i][j]-matAngleEnlarge[i][j]) <= wew) && (wew <= (matDirection[i][j]+matAngleEnlarge[i][j])) ){
matHconst[i][j]=1; //Part of the sector
//cout << "Part of the sector ---------------------------------------------------------------" << endl;
//cout << "matHconst[i][j]=1" << matHconst[i][j] << endl;
else{
matHconst[i][j]=0; //Not Part of the sector
//cout << "Not Part of the sector" << endl;
//cout << "matHconst[i][j]=0" << matHconst[i][j] << endl;
//Compute primary polar histogram Hp(k)
//cout << "firstfillPrimaryH" << firstfillPrimaryH << endl;
if (firstfillPrimaryH==0){ //If first fill at sector
//cout << "matMagnitude[i][j]" << matMagnitude[i][j] << endl;
//cout << "matHconst[i][j]" << matHconst[i][j] << endl;
float temp = matMagnitude[i][j]*matHconst[i][j];
//cout << "matMagnitude[i][j]*matHconst[i][j]" << temp << endl;
arrPrimaryH.push_back(temp);
firstfillPrimaryH=1; //Trigger flag
//cout << "arrPrimaryH kth" << arrPrimaryH.at(k) << endl;
else{ //If sector filled previously
arrPrimaryH.at(k) = arrPrimaryH.at(k)+(matMagnitude[i][j]*matHconst[i][j]);
firstfillPrimaryH=0; //Reset flag
