I am trying to work through the simple plugin example (http://wiki.ros.org/pluginlib/Tutorials/Writing%20and%20Using%20a%20Simple%20Plugin) but cannot get it to build for ROS2.
Trying to use https://docs.ros.org/en/foxy/Guides/Ament-CMake-Documentation.html and the details in the tutorial, but I have limited CMake experience and cannot get it to build. Are there available examples that use ROS2?
Any help would be greatly appreciated.
EDIT
Been trying to piece together a few different resources and have got things to build, but now the library can't be found so I must be doing something wrong.
The plugin failed to load for some reason. Error: %sCould not find library corresponding to plugin
I've set up two packages, once containing the base class and one containing the plugins
Folder structure
src
-controller
 -include
  -Controller.h
 -src
  -ControlFramework.cpp
 CMakeLists.txt
 package.xml
-linear_controller
 -include
  -LinearController1.h
  -LinearController2.h
 -src
  -LinearController1.cpp
  -LinearController2.cpp
 CMakeLists.txt
 linear_controller_plugins.xml
 package.xml
Base Class
Controller.h
#pragma once
namespace control_base
    class Controller
    public:
        Controller() {};
        virtual ~Controller() {};
        virtual bool initialize(double p, double i, double d) = 0;
        virtual double computeFeedback(double error) = 0;
#include <iostream>
#include <pluginlib/class_loader.hpp>
#include <controller/Controller.h>
using namespace std;
int main(int argc, char** argv)
  pluginlib::ClassLoader<control_base::Controller> poly_loader("linear_controller", "control_base::Controller");
  try
    std::shared_ptr<control_base::Controller> triangle = poly_loader.createSharedInstance("control_plugins::LinearController1");
    triangle->initialize(10.0, 0.0, 0.0);
    std::shared_ptr<control_base::Controller> square = poly_loader.createSharedInstance("control_plugins::LinearController2");
    square->initialize(5.0, 0.0, 0.0);
    cout << "Triangle area: %.2f" << triangle->computeFeedback(2.0);
    cout << "Square area: %.2f" << square->computeFeedback(2.0);
  catch(pluginlib::PluginlibException& ex)
    cout << "The plugin failed to load for some reason. Error: %s" << ex.what();
  return 0;
CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
project(controller)
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
if(CMAKE_COMPILER_IS_GNUCXX OR CMAKE_CXX_COMPILER_ID MATCHES "Clang")
  add_compile_options(-Wall -Wextra -Wpedantic)
endif()
# find dependencies
find_package(pluginlib REQUIRED)
#Include directories
include_directories(
  include
set(plugins_dependencies
  pluginlib
add_executable(${PROJECT_NAME}
  src/ControlFramework.cpp
ament_target_dependencies(${PROJECT_NAME} ${plugins_dependencies})
install(TARGETS ${PROJECT_NAME}
  DESTINATION lib/${PROJECT_NAME}
install(DIRECTORY include/
  DESTINATION include/
ament_package()
package.xml
<?xml version="1.0"?>
<?xml-model href="http://download.ros.org/schema/package_format3.xsd" schematypens="http://www.w3.org/2001/XMLSchema"?>
<package format="3">
  <name>controller</name>
  <version>0.0.0</version>
  <description>TODO: Package description</description>
  <maintainer email="[email protected]">angus</maintainer>
  <license>TODO: License declaration</license>
  <buildtool_depend>ament_cmake</buildtool_depend>
  <depend>pluginlib</depend>
  <test_depend>ament_lint_auto</test_depend>
  <test_depend>ament_lint_common</test_depend>
  <export>
    <build_type>ament_cmake</build_type>
  </export>
</package>
Plugin Package
LinearController1.h
#pragma once
#include <pluginlib/class_list_macros.hpp>
#include <controller/Controller.h>                      // Inheriting the base class
namespace control_plugins
  class LinearController1 : public control_base::Controller {
  public:
    LinearController1() {};                               // Constructor
                                                          // No destructor!
    bool initialize(double p, double i, double d);
    double computeFeedback(double error);
  private:
    double _p_gain{0};
    double _i_gain{0};
    double _d_gain{0};
#include <linear_controller/LinearController1.h>
  bool LinearController1::initialize(double p, double i, double d)
    _p_gain = p;
    _i_gain = i;
    _d_gain = d;
    return true;
  double LinearController1::computeFeedback(double error)
    return error*_p_gain;
PLUGINLIB_EXPORT_CLASS(control_plugins::LinearController1, control_base::Controller)
CMakeLists.txt
project(linear_controller)
# Default to C++14
endif()
endif()
#Find dependencies
find_package(controller REQUIRED)
  include
  ../controller/include
  pluginlib
  controller
add_library(${PROJECT_NAME}
  src/LinearController1.cpp
  ARCHIVE DESTINATION lib
  LIBRARY DESTINATION lib
  RUNTIME DESTINATION lib
install(FILES linear_controller_plugins.xml
  DESTINATION share
ament_export_include_directories(include)
ament_export_libraries(${PROJECT_NAME})
pluginlib_export_plugin_description_file(linear_controller linear_controller_plugins.xml)
ament_package()
package.xml
  <name>linear_controller</name>
  <depend>controller</depend>
  <export>
    <controller plugin="${prefix}/linear_controller_plugins.xml" />
  </export>
</package>
<library path="/liblinear_controller">
  <class type="control_plugins::LinearController1" base_class_type="control_base::Controller">
    <description>LinearController1 for control</description>
  </class>
  <class type="control_plugins::LinearController2" base_class_type="control_base::Controller">
    <description>LinearController2 for control</description>
  </class>
</library>
Originally posted by GusBus on ROS Answers with karma: 63 on 2021-06-11
So Using the diff_drive_controller I made quite a few changes to get things working:
Created Separate packages for plugins, base and executable: linear_controller (Contains Plugins) controller (Contains Base Class) control_framework (Contains Executable)
I then got the controller CMake to look very similar tot he controller_interface CMake and treated it as an exported library
One error I had in the code that I think was actually a large part of the problem was:
pluginlib::ClassLoader<control_base::Controller> ctrl_loader("linear_controller", "control_base::Controller");
Changed to name the right package containing the base class:
pluginlib::ClassLoader<control_base::Controller> ctrl_loader("controller", "control_base::Controller");
Thanks for the help and pointing me in the right direction!
Originally posted by GusBus with karma: 63 on 2021-06-14
