You are essentially making your own IMU. The way this works is essentially:
- the accelerometer gives you linear acceleration
- the rotational gyro gives you angular velocity
- integrate the rotational gyro over time to give you angular position
- integrate the accelerometer over time to give you linear velocity
- double integrate the accelerometer over time to give you linear position
Of course, integrations like this introduce errors, so that is why people typically combine estimates from many different sensors (and sensing modalities) with something like a Kalman Filter.
Also note that these integrations don't work anymore if you max out the sensing range of your sensors. For example, some cheap accelerometers won't measure over 3gs. And I imagine that swinging a bat and hitting a ball will produce some pretty high gs. And a low resolution (bit count) will also severely affect the accuracy.
