Hi, I have gone through the internet for hours for similar cases to mine but I've tried all solutions and hasn't got my code working. I'm using a library called "vdo_slam" which has been built and can be found in /usr/local/include/vdo_slam. In my project CMakeList.txt I can find_package(vdo_slam REQUIRED) with no error. The only problem I have is at the end of "catkin_build" I get several of these "undefined reference to ...." as shown below. I have tried several solutions as listed below. All these undefined references are declared and defined inside the "vdo_slam" package. Any help is appreciated. Thanks!
Known solutions I have taken:
  1. I looked for classes and functions mentioned in the errors and see if there are pure virtual destructors as mentioned in here but they are all defined solidly.
  1. I have tried to debug with "readelf" command as shown below referring to this. But i don't have the "libvdo_slam.so" which actually includes these functions in the error. I suppose i need to have "libvdo_slam.so" when i run this "readelf" command right? How can i add that?
Error code from "catkin_build":
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `typeinfo for VDO_SLAM::Visualizer2D'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `vtable for VDO_SLAM::Visualizer2D'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `vtable for VDO_SLAM::SceneObject'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `VDO_SLAM::BoundingBox::BoundingBox(double, double, double, double)'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `VDO_SLAM::Scene::Scene()'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `VDO_SLAM::Visualizer2D::spinOnce(std::shared_ptr<VDO_SLAM::Scene>&)'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `VDO_SLAM::Scene::add_scene_object(std::shared_ptr<VDO_SLAM::SceneObject>&)'
/home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so: undefined reference to `VDO_SLAM::Visualizer2D::Visualizer2D(std::shared_ptr<VDO_SLAM::VisualizerParams>&)'
collect2: error: ld returned 1 exit status
my_realtime_vdo_slam/CMakeFiles/ros_vdoslam_node.dir/build.make:226: recipe for target '/home/tranks/testing_ws/devel/lib/my_realtime_vdo_slam/ros_vdoslam_node' failed
make[2]: *** [/home/tranks/testing_ws/devel/lib/my_realtime_vdo_slam/ros_vdoslam_node] Error 1
CMakeFiles/Makefile2:6593: recipe for target 'my_realtime_vdo_slam/CMakeFiles/ros_vdoslam_node.dir/all' failed
make[1]: *** [my_realtime_vdo_slam/CMakeFiles/ros_vdoslam_node.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j12 -l12" failed
$ readelf --dynamic /home/tranks/testing_ws/devel/lib/libmy_realtime_vdo_slam.so Here
This is my CMakeList.txt:
cmake_minimum_required(VERSION 3.10)
project(my_realtime_vdo_slam)
  cv_bridge
  flow_net
  geometry_msgs
  image_transport
  mask_rcnn
  message_generation
  midas_ros
  mono_depth_2
  nav_msgs
  python_service_starter
  roscpp
  sensor_msgs
  std_msgs
  tf
  tf2
  tf2_geometry_msgs
  tf2_ros
  tf2_sensor_msgs
  vision_msgs
  visualization_msgs
  nodelet
  message_filters
find_package(OpenCV)
## Generate messages in the 'msg' folder
add_message_files(
   FILES
   VdoSlamScene.msg
   VdoSlamMap.msg
   VdoSceneObject.msg
   VdoInput.msg
generate_messages(
  DEPENDENCIES
    actionlib_msgs
    geometry_msgs
    std_msgs
    sensor_msgs
    mask_rcnn
    vision_msgs
set(PROJECT_INCLUDE_DIRS
  include
  ${catkin_INCLUDE_DIRS}
  ${OpenCV_INCLUDE_DIRS}
  ${vdo_slam_INCLUDE_DIRS}
include_directories(
  ${PROJECT_INCLUDE_DIRS}
catkin_package(
  INCLUDE_DIRS ${PROJECT_INCLUDE_DIRS}
  LIBRARIES ${PROJECT_NAME}
  CATKIN_DEPENDS
    roscpp
    image_transport
    std_msgs
    tf
    tf2
    tf2_geometry_msgs
    tf2_ros
    tf2_sensor_msgs
    nav_msgs
    sensor_msgs
    geometry_msgs
    cv_bridge
    flow_net
    mask_rcnn
    mono_depth_2
    midas_ros
    message_runtime
    nodelet
    message_filters
  # DEPENDS system_lib
add_library(${PROJECT_NAME} SHARED
  src/RosVdoSlam.cpp
  src/utils/RosUtils.cpp
  src/visualizer/RosVisualizer.cpp
    src/visualizer/RosAsyncManager.cpp
  src/tracking/HungarianSolver.cpp
    src/tracking/SemanticTracker.cpp
target_link_libraries(${PROJECT_NAME} PUBLIC
        ${catkin_LIBRARIES}
        ${OpenCV_LIBS}
        ${vdo_slam_LIBRARIES}
#if(catkin_EXPORTED_LIBRARIES)
#  add_dependencies(${PROJECT_NAME}
#         ${catkin_EXPORTED_LIBRARIES}
#         ${catkin_LIBRARIES}
#         ${OpenCV_LIBS}
 #     ${vdo_slam_LIB_DIRS})
# endif()
# target_include_directories(${PROJECT_NAME} SYSTEM PUBLIC
#     ${catkin_INCLUDE_DIRS}
#     ${OpenCV_INCLUDE_DIRS}
#     ${vdo_slam_INCLUDE_DIRS}
#     $<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
#     $<INSTALL_INTERFACE:include>
add_executable(ros_vdoslam_node
  src/ros_vdoslam_node.cpp
target_link_libraries(ros_vdoslam_node
  ${catkin_LIBRARIES}
  ${OpenCV_LIBS}
  ${PROJECT_NAME}
  add_dependencies(ros_vdoslam_node
          ${catkin_LIBRARIES}
          ${OpenCV_LIBS}
      ${vdo_slam_LIBRARIES})
endif()
Originally posted by TK27 on ROS Answers with karma: 16 on 2021-04-27
Comment by jayess on 2021-04-27:\
[...] I have gone through the internet for hours for similar cases to mine but I've tried all solutions and hasn't got my code working
What similar cases, what solutions, and what were the results? This information will help others not suggest things that you've already attempted. Could you please update your question with this information?
Comment by TK27 on 2021-04-28:
Yes Sorry i put it up in a rush. I have added what I have tried in the post. Please let me know if i need to add anything else. Thanks
Comment by gvdhoorn on 2021-04-28:\
target_link_libraries(${PROJECT_NAME} PUBLIC > ${catkin_LIBRARIES} ${OpenCV_LIBS} > ${vdo_slam_LIB_DIRS} # /home/tranks/testing_ws/src/VDO_SLAM/build/libvdo_slam.so )
I'm not saying it will solve your problem, but you're not linking correctly here.
target_link_libraries(..) takes either a CMake target, or a (list of) absolute paths to libraries.
You're passing it a directory (if the naming of vdo_slam_LIB_DIRS is correct).
@gvdhoorn Yes it should be ${vdo_slam_LIBRARIES} instead. I found that my current library is not linked to that libvdo_slam.so when I ran the $ldd or $readelf on the my library so file. Shouldn't it be linked since I already did target_link_libraries(... vdo_slam_LIBRARIES ...)?
I got a solution here:
Eureka! I found a solution although it's not an ideal one. As mentioned in the question, I noticed that libvdo_slam.so was not listed as a shared library when running $ readelf <on_my_library.so>. So I manually added -lvdo_slam in the CMakeList.txt so it looks like:
  ${catkin_LIBRARIES}
>       ${OpenCV_LIBS}
  ${PROJECT_NAME}
>       -lvdo_slam
> Moreover, since "vdo_slam" also uses a modified "g2o" library, the same procedure had to be done in the VDO_SLAM library's CMakeList.txt(which is adding `-lvdo_slam_g2o` in a similar place).
> Although it builds successfully now, I still wonder why this happened. From my understanding, `-lvdo_slam` is the same as `${vdo_slam_LIBS}`, and the latter should be valid after using `find_package(vdo_slam REQUIRED)`
Originally posted by TK27 with karma: 16 on 2021-05-02
Comment by gvdhoorn on 2021-05-02:
Please do not post link-only answers. This is not accepted on Stack Overflow, neither here on ROS Answers.
I've quoted your StackOverflow answer in your answer here.
Comment by TK27 on 2021-05-02:
@gvdhoorn Thanks for the notice. Cheers
