Hi everyone,
I'm having trouble running ROS across multiple machines. I have my ROS Master running on a robot (based on the NVIDIA Jetson Nano) and I'm trying to visualize some data on my laptop via Rviz but with no success.
I did the usual set up of environment variables on the Nano (where 192.168.1.109 is the Nano's ip):
export ROS_MASTER_URI=http://192.168.1.109:11311
export ROS_IP=192.168.1.109
roscore
as well as the following on my laptop (192.168.1.110 is my computer's ip):
export ROS_IP=192.168.1.110
But whenever I try to run some node on my laptop (tried it with rviz and several simpler nodes), it will just hang for a while until it raises the following error:
[ERROR] [1618945845.530120204]: [registerPublisher] Failed to contact master at [192.168.1.109:11311].
Retrying...
The weird thing is that I can easily ssh into the Nano, but for some reason my ROS on my laptop won't connect to the master on the Nano. Please excuse me if I'm missing something really obvious here, it's been a while since I last used ROS, but I do recall that setting up a communication across different machines was not difficult at all.
I'm not sure if it helps but I'm running ROS Melodic on the Nano (Ubuntu 18.04) and ROS Noetic on my laptop (Ubuntu 20.04).
Thank you all!
Originally posted by pfontana96 on ROS Answers with karma: 18 on 2021-04-20
Comment by shonigmann on 2021-04-20:
-disregard- To my knowledge, cross-distribution compatibility is not possible. I believe to run ROS across different machines, each machine would need to be running the same ROS version. In your case, that would be Melodic on both machines or Noetic on both machines.
Comment by jayess on 2021-04-20:
@shonigmann It is definitely possible to mix different versions of ROS. For example, I've run Hydro, Indigo, Kinetic, and Jade all at the same time interacting with each other. Now, there may be some issues with messages (I can't remember exactly all of the issues as this was 3+ years ago), but this totally doable (mixing different versions of ROS).
@pfontana96 Have you gone through this tutorial?
I stand corrected then! glad you chimed in. helps build my own understanding. I figured as API/ABI compatibility isn't enforced between releases, that cross-release interaction would be tricky. But interesting that it is/was possible.
Comment by gvdhoorn on 2021-04-21:\
the comment by @jayess is specifically about compatibility between nodes using ROS messages, services and/or actions.
The middleware acts as an abstraction layer there, which nicely hides any API/ABI problems, as messages are sufficiently standardised (both syntax and semantics).
Comment by shonigmann on 2021-04-21:
thanks for the clarification
@pfontana96: you write:
is your laptop running Ubuntu natively, or is it a VM?
If natively: is there perhaps a firewall active?
Originally posted by gvdhoorn with karma: 86574 on 2021-04-21
Comment by pfontana96 on 2021-04-21:
Thank you @jayess, I had not gone thorugh that tutorial before, but the netcat let me realise that @gvdhoorn was right and the nano had indeed a firewall active!! After disabling it, it worked fine. Thank you a lot!
Comment by androadi on 2021-12-10:
Hi @pfontana96 I am facing the same problem with a rpi4b (connected via ssh). Could you let me know what are the netcat commands to determine that a firewall is active and how to deactivate it?
