I am using ubuntu mate 20.04 focal and i have installed ros noetic, I am trying to use a logitech c920 webcam, however when i run rosrun usb_cam usb_cam_node i get the following error [swscaler @ 0x229f390] no accelerated colorspace conversion from yuv422p to rgb24, [swscaler@ 0x229f390] deprecated pixel format used, make sure you set the range correctly
i read that these are just warnings however, when i run rosrun rviz rviz it doesn't display the image from the webcam
the webcam does work though if i open it through Cheese or vlc it displays just fine
i have tried using the fixes found here
https://answers.ros.org/question/173501/problem-displaying-webcam-on-beaglebone-black-ros-hydro/
and here
https://github.com/ros-drivers/usb_cam/issues/91
and here
https://github.com/ros-drivers/usb_cam/issues/67
however, no of these solutions have seemed to work i've also tried changing the ffmpeg code in the usb_cam.cpp code but i haven't been able to get that to work either.... when i run v4l2-ctl --list-formats-ext -d /dev/video0 i get the following
ioctl: VIDIOC_ENUM_FMT Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
        Interval: Discrete 0.033s (30.000 fps)
        Interval: Discrete 0.042s (24.000 fps)
        Interval: Discrete 0.050s (20.000 fps)
        Interval: Discrete 0.067s (15.000 fps)
        Interval: Discrete 0.100s (10.000 fps)
        Interval: Discrete 0.133s (7.500 fps)
        Interval: Discrete 0.200s (5.000 fps)
i think the problem is that it's using deprecated ffmpeg code to try and convert it from yuyv to mjpeg? but i'm not sure if i'm right about this....
how do i fix this? please help..... is there another ros package that i could try?
Originally posted by golferGuy1145 on ROS Answers with karma: 1 on 2021-04-15
I had the same problem, I solved it by adding _pixel_format:="yuyv" to the rosrun command. I hope this helps.
Originally posted by SamRodriguez with karma: 61 on 2021-11-16
