Hi, I'm using a node on en jetson nano running melodic, that publish Image topics. I will calibrate the camera with cameracalibration.py in order to get calibration yaml file. Then I will need to undistort (rectifie?) the image using data from yaml file. Is there a package, node, tool that read a yaml file, subscribe to image topic and publish camera_info and undistorted images?
Thank
Originally posted by elgarbe on ROS Answers with karma: 106 on 2021-04-07
Take a look at image_proc it should be able to handle exactly your problem.
Originally posted by Tristan9497 with karma: 220 on 2021-04-07
Comment by elgarbe on 2021-04-07:
ok, that's a middle point becouse it needs a camera_info message. So, I need a package/node that reads yaml calibration file and publish a camera_info. do you know any?
Comment by Tristan9497 on 2021-04-07:
Unfortunately i don't, but writing a node yourself does not seem to complicated. Take a look at this for reference
