I am not sure how i should explain this, I am looking for a way to plot the trajectory an robot arm. An object is seen from the toolFrame frame, but how do I plot the position of each joint, such that the frame they uses are the same.
One way would be to use the world frame as reference, but how would i plot the position of the object related to the world frame?
5
  • $\begingroup$ What environment are you drawing in? Matlab? Is there a mathematical model of the robot available in that environment? $\endgroup$ May 17, 2016 at 9:11
    $\begingroup$ Matlab.. I have a mathmatical model, but not coded in matlab. At the moment I just multply different transformation matrices to get the point i want the desired transformation $\endgroup$ May 17, 2016 at 9:17
  • $\begingroup$ "An object is seen from the toolFrame frame" this is what makes it a little unclear to me what you want exactly. Do you want to visualize the trajectories in the tool frame? $\endgroup$ May 17, 2016 at 10:26
  • $\begingroup$ The position of the object is given relative to the tool frame. $\endgroup$ May 17, 2016 at 10:57
  • $\begingroup$ I would like to visualize trajectory of the whole robot arm, each joint.. $\endgroup$ May 17, 2016 at 10:57
Assuming you have solved the inverse kinematics (IK) problem already...
I suppose you have a transformation matrix for each joint, build up from one line in the DH table (if you used DH to describe the robot). Form the IK you have obtained
$Q = [q_1, q_2, q_3, q_4, q_5, q_6]$
Having all Q values you can now write:
$H_{0,1} = A_1(q_1)$
$\Rightarrow$ $H_{0,1}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 1
$H_{0,2} = H_{0,1}*A_2(q_2)$
$\Rightarrow$ $H_{0,2}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 2
$H_{0,3} = H_{0,2}*A_3(q_3)$
$\Rightarrow$ $H_{0,3}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 3
$H_{0,4} = H_{0,3}*A_4(q_4)$
$\Rightarrow$ $H_{0,4}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 4
$H_{0,5} = H_{0,4}*A_5(q_5)$
$\Rightarrow$ $H_{0,5}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 5
$H_{0,6} = H_{0,5}*A_6(q_6)$
$\Rightarrow$ $H_{0,6}(1:3, 4)$ will give you the $x$, $y$ and $z$ Coordinates of joint 6
$H_{0,tool} = H_{0,6}*A_{tool}$
where
  • $A_i$ is the DH-transformation matrix associated with joint $i$.
  • the index $_0$ represents the world frame
  • the intex $_{tool}$ represents the tool frame
  • $H_{i,j}$ represent the transformation matrix from frame $i$ to frame $j$
9
  • $\begingroup$ What about the position of the object related to the world? $\endgroup$ May 17, 2016 at 12:11
  • $\begingroup$ I don't know if thats wasn't clear, but my problem is the axis is misalligned, as the position of objected is logged according to the tool $\endgroup$ May 17, 2016 at 12:13
  • $\begingroup$ If you solved the inverse kinematics then it does not matter...that is why the answer starts with "asuming you have solved the IK" $\endgroup$
    – 50k4
    May 17, 2016 at 12:14
  • $\begingroup$ did you solve the IK? $\endgroup$
    – 50k4
    May 17, 2016 at 12:15
    $\begingroup$ If I understand correctly, you have all the joint angles ($Q$). Those define the pose of the robot regardless of any other frames. Those are always expressed in their local frames. The transition from world frame to frame of joint 1 is $A_1$. The transition is dependent on joint angle and robot geometry only. You transition by multiplication and plot the frame origin (x, y and z). Then you go to the next joint and plot the frame origin and so on until you reach the end-effector. At the end you will get the location of each joint in world frame. connect the lines and you can draw your robot. $\endgroup$
    – 50k4
    May 17, 2016 at 14:25
