I want to go a little deeper into the "why" from a technical perspective. Not just you must do this, but why. I've looked at the rospy source code but I am still not sure about the following. Given this very common pattern:
rate = rospy.Rate(10)
# do stuff
rate.sleep()
Why is a rospy.spinOnce() not required? Or is it required? Because when I read the source of rate.sleep() didn't see that sleep include the spinOnce functionality which would imply that callbacks wouldn't be happening as a result of .sleep() or of is_shutdown(). But in fact callbacks do seem to be happening, so I must be misunderstanding a detail.
Refined restatement
Let me restate this in a very focused way. In python when must spin() used and when is spinOnce() used?
Originally posted by pitosalas on ROS Answers with karma: 628 on 2021-03-31
Comment by gvdhoorn on 2021-03-31:\
The initial two commenters contradict each other which shows that this is a tricky thing to really understand!
not really.
The answer is incorrect. @Delb's comment is correct.
This has also been discussed before here on ROS Answers.
roscpp
and rospy
just have different threading models.
Comment by miura on 2021-03-31:
@gvdhoorn Thank you for your comment.
I would like to revise my answer. Could you please let me know the deficiencies?
I would like to describe my perception. I was answering about "Why is a rospy.spinOnce() not required? Or is it required?" I understand that @Delb has supplemented about spin() in python.
The question is specifically about rospy
You link to roscpp
tutorials and state the same "should apply to Python". But that's not correct.
roscpp
and rospy
handle these things differently.
@Delb already made that clear.
Thank you. I'm going to leave the answers and comments as they are now.
I thought about deleting the wrong comment, but I think it would make @Delb's comment a bit confusing.
If there is a good way to fix it, please let me know.
