I'm trying to implement obstacle avoidance using move_base package on ROS 1 Melodic. Current issue is that when the robot approaches a short obstacle, the obstacle is first correctly drawn to local costmap, but closer the robot gets to it, it starts to clear it from the costmap. I believe this happens because of the fact that the camera has a blind spot (~30cm) in front of the robot. When the camera doesn't see the obstacle anymore, move_base obstacle layer does raytracing over it to the next nearest obstacle and clears the closest one from the costmap. Desired behavior would be that the robot doesn't remove the obstacle from local costmap even when it is in the blind spot.
So the question is, is there a way to avoid this from happening? I believe one solution would be to have minimum distance for the raytracing (== 30cm, length of the blind spot), under which raytracing is not done, but move_base currently doesn't seem to have this sort of parameter.
I'm using Intel D435i depth camera which publishes a pointcloud from short distance and a laser scan from longer distance. This is how the obstacles layer looks like:
obstacles_laser:
    observation_sources: camera_1_obstacles camera_1_laser
    camera_1_laser: {data_type: LaserScan, clearing: true, marking: true, topic: /camera_1/laser_scan, obstacle_range: 5.5, raytrace_range: 6.0 }
    camera_1_obstacles: {data_type: PointCloud2, clearing: true, marking: true, topic: /camera_1/obstacles_cloud, obstacle_range: 5.5, raytrace_range: 6.0}
Robot approaching a short obstacle:
image description
Robot has moved close enough for the obstacle to disappear from the local costmap
image description
Visualization of the blind spot of the Intel camera. Visible area marked with orange points.
image description
Originally posted by jannkar on ROS Answers with karma: 36 on 2021-03-30
I know this doesn't help you for ROS1, but we added minimum obstacle and raycasting ranges for ROS2 Nav2's costmap_2d package https://navigation.ros.org/configuration/packages/costmap-plugins/obstacle.html such that you can stop clearing in the sensor's deadzone.
Originally posted by stevemacenski with karma: 8272 on 2021-03-30
Comment by jannkar on 2021-03-31:
Nice! We will switch to ROS2 in the near future, so it is great to hear that this feature is already supported. So maybe I'll try to come up with some quick workaround while using ROS1. Thanks!
