Is it possible to perform cosine interpolation between two transformation matrices?
It make sense for the translation part, but how about the rotational part?
| improve this question | | | | |
Yes, you can.
same as for the translations, you extract the 3 angles form the matrix, you have the starting angles and the target angles. Interpolate as you wish (sync-async, cos-spline-linear) and for each timestamp you can re-create the matrix (knowing the 3 angels and the 3 translations).
Advantage for cos-interpolation would be the continuity of higher order derivates (same as in the case of the interpolation for the linear axes)
| improve this answer | | | | |
